02-07-2021, 03:00 PM | #1 |
Rep 3,066
G30 M550i N63B oil wrench/socket
Someone please point me in the direction of the correct oil filter wrench/socket for 2020+ N63B oil filter (523hp version).
Here is the oil filter cap: https://www.ecstuning.com/b-genuine-...p/11427615389/ I believe it is a 86mm diameter... |
05-09-2021, 02:50 PM | #3 |
Rep 3,066
06-08-2021, 12:47 PM | #4 |
Rep 295
This is the factory BMW oil filter cap wrench. 86mm, 16 flats.
https://www.fcpeuro.com/products/bmw...40-83300493936 There may be cheaper alternatives, but I have found you rarely regret using the factory approved tool. It will fit without damaging the plastic cover, and simply works. Unless another tool has been vetted by other users... I've been down that rabbit hole trying two or three until one works without slipping off the cap or filter. I've had some work for a few uses, then go to sh*t. Of course right when I am trying to get the proper torque setting....and its slipping off. |
