07-09-2020, 05:36 AM | #1 |
Rep 299
M2 brakes on a 340i work?
Hi all
Per title would a set of m2 brakes bolt right on a f30 340i or would knuckles need to be changed? Thanks
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox. |
07-27-2020, 10:36 PM | #2 |
Rep 314
I am pretty confident they will fit but I believe the 2 series has smaller pistons in the rear calipers. Check realoem.com before you buy.
'16 340i M-Sport F30 Estoril blue, Oyster, Bootmod3, CTS high flow cat, CTS intake
Sold:'07 335i E90 Montego Blue on black leather, Navi, premium, sirius, sport pkg, CA, logic7 Sold: '07 328i E92, SG, Saddle Brown, Gray Poplar, ZSP, CA, Heated Seats, BMW Performance Exhaust, BMW performance SSK, Valentine1, european delivery - Military Sales |
07-28-2020, 03:17 PM | #4 |
Rep 1,934
Yes all of the M2 calipers will fit, even the 400mm fronts from CS. Again m2,3,4 all use the same brembo calipers as our F30 35/40i get in mperformance/msport 370/345.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
07-29-2020, 06:13 PM | #5 | |
Rep 619
Also, if the OP is wanting to bolt on an full F87 M2 4 pot 380mm front / 2 pot 370mm rear brake set up - then no, it won't fit. The calipers, as you say, are the same, but rotor fitment is different as the F3x is designed to use 370/345 and trying to put 380/370 rotors onto a F3x will not work. |
07-29-2020, 06:28 PM | #6 | ||
Rep 1,934
07-30-2020, 06:24 AM | #7 | |
Rep 619
It would need adjusting to have height removed from the bracket to accommodate the extra height in the caliper. |
