06-30-2020, 12:54 PM | #1 |
Rep 206
Spacer sizes??
Im still trying to decide on spacer sizes. Are there suggestions? Examples? Standards? I have the H&R super sport speaks with 19" factory offset wheels (front: 225/40 r19 rear: 255/35 r19)
Maybe pictures??
2016 BMW 435i M-Sport
- JB4 and MHD - xHP - Injen intake - Active Autowerke intercooler - Active Autowerke charge pipe - AWE catback *** I want more!!!*** |
06-30-2020, 05:41 PM | #2 |
Rep 141
Drives: 2016 BMW 340i RWD
I'm running 19" factory wheels with the tire specs you mentioned. I'm sitting on Dinan springs with bms 12mm fronts and 15mm rears
2016 BMW 340i | DINAN Lowering Springs | DINAN Stage 1 v1 Tune | DINAN Mid Pipe | DINAN CAI | DINAN Turbo Inlet Pipe | Koni Sport Dampers | BMS 12/15 mm Spacers | Active Autowerke Exhaust
exE36M3487.50 |
06-30-2020, 08:29 PM | #3 |
F36 GC
143
Rep 259
When I still had 225/255 I was running 10 front and 18 rear. Started at 10 front/15 rear before moving to 18 rear. I think 12 would have been perfect up front. Recommend the BMS spacers as well.
06-30-2020, 10:35 PM | #4 | |
Rep 206
ozymandias435142.50 |
07-01-2020, 07:38 AM | #5 | ||
F36 GC
143
Rep 259
07-01-2020, 07:40 AM | #6 |
F36 GC
143
Rep 259
07-01-2020, 08:07 PM | #7 |
Rep 141
Thanks bro. Big fan of chemical guy detail products
07-02-2020, 04:28 PM | #8 |
Rep 320
what size tire are you running? 10mm/12mm up front and 15mm in the rear works well. I am running 15mm up front and 20mm in the rear. I'm running a 225 wide tire on the street...
07-03-2020, 02:45 PM | #9 |
Rep 141
I'm running 225 40/19 up front and 255 35/19 in the rear. It's the stock OEM tires and rims
07-05-2020, 01:48 PM | #10 |
Rep 233
I had 10f/12r H&R before I installed the F80 control arms and tension struts. That mod pushes the wheel out so i took the front spacers off.
Its definitely not as aggressive as what most ppl run but im not a nig fan of tire poke. |
