06-24-2020, 05:36 PM | #1 |
Rep 65
Swift springs on f30 w/stock EDC
After a lot of research I have decided to drop my F30 335i on some Swift R springs paired with my stock EDC suspension and I couldn't be happier! These are very popular among the F80 owners so I decided to pull the trigger and do it. I also didn't see to many post of pics for F30s dropped on them so I've added some before and after pics! As for the ride quality.... It's how these cars should have came from the factory! Body roll has decreased significantly and taking corners and turns is super tight! It's just as comfortable as my stock springs if not better. It just feels more refined and the EDC handles it very well! Once it settles I can update with exact drop specs but the back dropped about a quarter inch and the front should be an inch. Compared to my buddies car with the h&r sports I would choose Swift all day.
F30 335i Glacier Silver 6MT
06-24-2020, 07:59 PM | #2 |
Rep 141
Drives: 2016 BMW 340i RWD
Looks nice. I like the drop. Thanks for sharing
2016 BMW 340i | DINAN Lowering Springs | DINAN Stage 1 v1 Tune | DINAN Mid Pipe | DINAN CAI | DINAN Turbo Inlet Pipe | Koni Sport Dampers | BMS 12/15 mm Spacers | Active Autowerke Exhaust
06-24-2020, 11:59 PM | #3 |
Rep 79
Curious how these would work out on an xDrive. My calculations suggest that it would lower an xDrive about 10mm more in front than a RWD, with roughly the same drop in back. I wonder if we could throw a 10mm isolator between the spring and bearing up front to even it out.. I loved the Swift/B8 combo I had on my Z.
06-25-2020, 01:19 AM | #4 | |
Rep 281
Drives: 2016 EB 340i
Last edited by Aldor27; 06-25-2020 at 01:20 AM.. Reason: Adding question about wheels. |
06-25-2020, 11:34 AM | #7 | |
Rep 65
Front: 18x9 ET 42 w/5mm spacers Rear: 18x9.5 ET 43 w/10mm spacers I don't have any rubbing. |
Aldor2787.00 |
06-25-2020, 11:39 AM | #8 | |
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
alohasurftoad3081.50 kilogram70.00 |
06-25-2020, 12:32 PM | #9 | |
Rep 272
Front drop should be lower than the 335 swifts since the f80 is lower on OE |
06-25-2020, 02:47 PM | #10 | ||
Rep 281
06-26-2020, 01:31 PM | #11 | ||
Rep 79
06-27-2020, 11:57 AM | #13 |
Rep 79
Sorry, I'm confused. Are you using the Swift Spec-R (p/n 4X915R) lowering springs with BC dampers? Or OTS Swift coilover springs on the BCs? I'm hoping for info on the 4X915R springs/xDrive combo, though I'll never turn down a pic of someone's mods
06-27-2020, 12:04 PM | #14 | |
Rep 79
06-27-2020, 03:09 PM | #15 | |
Rep 320
its raining at the moment here but when it stops, I will snaps some pics and post them here to give you a better idea... Last edited by brigade24; 06-27-2020 at 03:17 PM.. Reason: claritin clarity |
kilogram70.00 |
06-28-2020, 10:54 PM | #16 |
Rep 281
06-30-2020, 05:47 PM | #17 |
Rep 65
06-30-2020, 08:45 PM | #18 |
Rep 320
Here are some pics of my setup...street and pic lapping. Excuse the dirt, it was raining at my last race and the paddock was muddy so...fun.
the lapping setup is 275 wide all round. 3mm spacers in the back and 20mm in the front. I will explain the latter in the next post. there are so many performance mods that would give the car more of competitive edge but for some bizarre reason I want some bright orange or yellow calipers! The performance benefit is almost nil in autox...and yet I'm obsessed with doing this mod...I understand what suffering in silence means. Last edited by brigade24; 06-30-2020 at 09:09 PM.. Reason: brain phart |
06-30-2020, 09:03 PM | #19 |
Rep 320
Ok, the 275s will fit all round but you will need to camber in, you will need a spacer (10mm minimum) for the front and you MUST NOT run an 8"inch spring in front, run a 7" spring and you'll be golden...pic #2 is with a 15mm spacer and pic#3 is with a 20mm spacer. I still need to camber in so the tires will not stick out...i hope.
the last two pics are my front alignment markings and rear spring setup. That alignment marking needs to be rotated 540 degrees so that the yellow marking faces the rear of the car. doing that will induce a toe out condition of about 1/16th (total), maybe slightly less...this must be done on both sides before every race. |
Aldor2787.00 |
06-30-2020, 10:24 PM | #20 | |
Rep 281
brigade24156.00 |
07-01-2020, 08:05 AM | #22 | |
Rep 272
it should work, i've been wanting to copy this 275/40/17 setup... |
