06-17-2020, 08:51 AM | #1 |
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
M Performance Brake Upgrade
Hi everyone, I have 2015 435i with the standard brakes. I'm going to need new brakes all the way around in 4700 miles and I figured I'd just do the upgrade in one shot. Now, if I get it done at the dealer, do they reprogram the car for the bigger rotors and bigger calipers in the rear?
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
06-17-2020, 12:33 PM | #2 |
Rep 10,256
06-17-2020, 12:37 PM | #3 | |
Rep 1,119
06-17-2020, 01:02 PM | #4 | ||
Rep 379
As for brakes, no coding is needed, the car is precoded for the MP BBK already. Just got it done myself, didn't code anything, just plug and play. no problems. |
06-17-2020, 01:27 PM | #5 |
M Enthusiast
438
Rep 626
Drives: 2018 F80 M3 ZCP
If you have the 340/330 brakes currently, you're going to need to code after the MPBBK.
Many members here reported feeling mushy pedals without coding. If you dig, there are threads on the coding instructions for the 370/345 brakes.
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC 2017 F30 340i (SOLD) 2015 F82 M4 (SOLD) |
Boostedphil698436.00 cosmicdebris48059125.00 |
06-17-2020, 01:28 PM | #6 | |
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
FYI- The MP Brake Kit is a generic product meant to fit any F3x. The calipers in the MPBK are the exact same calipers as the M Sport blue brakes that are on some 435i's. They are all Brembo front 370mm and Brembo rear 345mm. The only difference is that in the MPBK, instead of painting the calipers blue, they paint them red, yellow or orange. The kit also comes with four sets of brake pads that are average at best. And two front dimpled/slotted rotors that are noisy. They are for show, not actual street performance. The kit's generic instructions say to code the car because some F3x cars with lower level brakes will need to be coded. A 335i/435i/340i/440i with either grey 340/330 or blue 370/345 brakes does not need to be coded because the front/rear brake ratio setting is the same. Since the MPBK is generic it also does not come with rear brake rotors. The kit requires a 345mm x 24mm rear rotor. But some mostly earlier and lower end F3x came with rear 160mm handbrakes built into smaller hat brake rotors. Other F3x came with larger 185mm hand brakes that required larger hat rear rotors to fit inside. Your 435i has a 185mm handbrake so for the MPBK on your car, you would need rear rotors that are 345mm x 24mm with a 185mm handbrake fitment inside larger rotor hats. (This is the most common size) When you say that you have standard brakes, you mean grey brakes and not blue brakes, correct? How many miles are on your car? How long have you had it? Do you know if brake pads or rotors have ever been changed? If you came up with 4,700 miles before needing new brakes all around from the dash computer, it is not accurate AT ALL! It is some computer guess, that is not based on any data whatsoever. You could have 25,000 miles remaining on your brakes. The only way to tell for sure is to measure the current thickness of your pads and rotors. If you are in Philly and need an independent BMW mechanic, I know one right over the bridge in SJ who is excellent. |
06-17-2020, 07:40 PM | #7 | ||
Rep 870
johnung4528.00 |
06-17-2020, 07:44 PM | #8 | ||
Rep 1,119
06-18-2020, 04:10 AM | #9 | |||
Rep 5,392
If you insist on going to a dealer use Thompson BMW because they have a mod shop so they are experienced and shouldn't screw it up. Best price on MPBK is $1,795 at GetBMWParts website. Buy matching Zimmermann rotors for your rears making sure to get the correct rear rotors for the 160mm or 185mm handbrake that's on your car. (335i/435i have more common 185mm) A reasonable Indy labor price to install an MP Brake Kit is $400-$450. |
06-18-2020, 06:24 AM | #10 | ||||
Rep 1,119
06-18-2020, 09:48 AM | #11 | |
No 55mph
1622
Rep 8,476
When I went from the Gray 4 piston Brembo/340 fronts & single Bosch/330 rears, to the Blue 370/345 brakes on my F32, I was told that coding/programming was not necessary I feel no detriment to not coding MPerf brakes in this situation
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
06-18-2020, 10:48 AM | #12 | ||
Rep 5,392
Boostedphil698436.00 |
06-18-2020, 02:51 PM | #14 |
Rep 8,942
Don't do the BBK they make a lot of annoying ticking noise, and use the same rotors side to side so they lean forward on one side of the car and rearward on the other. Keep your blue calipers, upgrade the rotors to StopTech slotted, pads Hawk HPS ceramic, stainless lines, Motul RBF600. I had Thompson do my F31 BBK upgrade because I had base grey 328 brakes to start with. They recommended this path for replacement when BBK stuff wears out. Will save you some money and you'll end up with a better setup.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
06-18-2020, 03:57 PM | #15 | |
Rep 5,392
BEM-S44515.50 |
06-18-2020, 04:04 PM | #16 | ||
Rep 8,942
Lots of good pad and rotor options, think we agree that BBK isn't the best choice either for performance or value. Can spend less and get a better result.
2022 Macan S
johnung4528.00 |
06-18-2020, 04:55 PM | #17 | |
Rep 164
06-18-2020, 05:48 PM | #18 | ||
Rep 5,392
You can buy a used set of all four 370/345 calipers for $700-$1,100 depending on cosmetic condition. Just watch the classified postings |
06-18-2020, 06:06 PM | #19 | ||
Rep 870
06-18-2020, 06:10 PM | #20 | |
Rep 164
johnung4528.00 |
06-18-2020, 06:14 PM | #21 | |||
Rep 5,392
Don't fall for "packages". It's a scam for companies with one strong component to try to increase their sales by getting you to also purchase another component from them that is weaker compared to its competitors. Buy the best component in each category. |
DJSF3014142.00 |
06-18-2020, 06:32 PM | #22 | |||
Rep 5,392
ECS in the past couple of years has quietly been buying up other retailers in this space like Turner, Pelican Parts and more. So you may think that you are searching around for a good price. But if you are actually looking at 2, or 3, or 4 retailers all owned by ECS, you may be seeing the same high price set by the parent company, ECS! I just saw ECS selling a set of four Hawk 5.0 pads for $312 that I bought not long ago for about $225. For a minute I thought maybe Hawk raised prices or something. Not so! It was ECS creeping up the price to increase their profits. Took me about 3 minutes to find a reputable vendor (not some eBay basement operation) selling the same thing for $210 shipped! |
DJSF3014142.00 |
