06-13-2020, 12:18 AM | #1 |
Rep 206
Drilled/slotted rotor brake set recommendations
Im dying to replace my M-Sport brakes setup, im getting a horribleeeee squeak as soon as i hit the brakes. Ive brought it to three different dealerships and they have all given me different excuses for why they cant fix it. Frankly, im over it and would rather put on a good replacement set. Im not going the brembo route, would like to keep costs low. Id love some recommendations!!! I found these, wasnt sure if they are worth putting on. Its a daily driver, judt want the squeaking to endddddd
2016 BMW 435i M-Sport
- JB4 and MHD - xHP - Injen intake - Active Autowerke intercooler - Active Autowerke charge pipe - AWE catback *** I want more!!!*** |
06-13-2020, 02:15 AM | #2 |
Rep 2,806
Drives: F33 430 and F39 M35i
grease the pads where you have metal to metal contact (obviously not where it contacts the rotor)
06-13-2020, 07:37 AM | #3 |
Rep 206
I would definitely love to save money already. I finally lost it on the third dealership. They told me the pads looked fine but the rotors are kinda at the end. They weren't pitching their rotors, in fact she even told me aftermarket are prefect cause they aren't covered with the extended warranty. I will not resurface the rotors. Is changing the pads worth it? Ive also been told hard vs. cold pads are night and day. Thsnk you!
06-13-2020, 09:33 AM | #4 |
Rep 1,827
FWIW, I tried a set of PowerStop pads and they squeaked a lot. Not sure if they're the same pads that come with the set you posted pics of though. You could always piecemeal a set. It's not uncommon to find posts for rotors in the classifieds here. Pair them with quality pads that are low-noise and you'll be set.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
06-13-2020, 09:37 AM | #5 | |
Rep 206
06-13-2020, 11:03 AM | #6 | ||
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
Mechanics tick me off when they give opinions rather than measurements. If some says you need new rotors ask them what your rotors measured. The wear material on BMW rotors is 1.6mm. No one can eyeball that and tell you anything. Don't fall for the "feel the ridge at the edge of the rotor" nonsense. Meaningless! Tactic used to sell new rotors! The procedure is to measure rotor thickness with a millimeter caliper at 8 random spots on the wear surface and take the lowest number. Obviously if the lowest number is way different then the caliper was probably held at an angle or something that provided an incorrect measurement. If a mechanic is showing you 8 thickness measurements of your rotor then he is a keeper who you can trust! Squeaks are most commonly caused by poorly greased brakes. The brake grease is an integral component in the brake system. The procedure is in Bentley manual and on newtis website. See photo. If you are going to start replacing components then: Brake pads are most critical component. Get Hawk 5.0. Best street pads by far. Best bite, instant warm up and light dust that washes right off. See photo for part numbers. If you have a 435i with blue M Sport brakes then you have 370mm front and 345mm rear brakes. Avoid slotted or dimpled rotors. They are noisy and provide little performance value. Plain rotors are fine for the street. If you want a rotor upgrade get crossdrilled. (Not crossdrilled and slotted. Avoid slotted for street use!) Crossdrilled rotors provide the best bite by far and the best performance in the rain because water can't trap between rotor and pad surfaces. There is a reason why Porsche, Mercedes and McLaren all install crossdrilled rotors on their street performance cars. If you can only afford to upgrade one axle then put crossdrilled rotors on the front which do the most work. The rear helps too, if you can afford it. Plain rotors- get Zimmermann. Same high quality as BMW but also zinc coated against rust, and much less expensive. ZIMMERMANN Front 370mm plain 2-piece 150.2911.32 Upgraded Front 370mm crossdrilled 150.2911.52 (Recently ~$113 each) Rear 345mm plain 2-piece with 185mm handbrake 150.2919.32 With older 160mm small hat handbrake 150.2921.20 See photo for handbrake sizes. You must install a rear rotor that matches the size of handbrake that came with the car from the factory. STOPTECH CROSSDRILLED StopTech are a more expensive crossdrilled option because they are designed with specific left/right sides for best vane cooling. Not sure how much it really matters for daily street performance over Zimmermanns but they look nice. StopTech have black rotor hats. $325/pair is an excellent price Front 370mm Crossdrilled 128.34144L 128.34144R Rear 345mm Crossdrilled with 185mm handbrake 128.34147L 128.34147R Ultimate front rotors are StopTech 370mm full floating crossdrilled with rust coating part# 81.B39.9941 Upgrade your rubber brake hoses to stainless steel brake lines for much more solid brake pedal feel. StopTech is ~$107/ set of four Hope this helps! |
06-13-2020, 12:48 PM | #7 |
Rep 3,748
If you want cross drilled rotor there a cheaper option than stop tech. R1Concept nLine rotor. They are sponsor here.
There rotor is not that bad...you can actually change your rotor every time you change your pad. |
06-13-2020, 01:17 PM | #8 | |
Rep 5,392
Zimmermann drilled is a high quality 2-piece German rotor with zinc coating, so its higher quality than BMW stock rotors. StopTech is at a higher lever than that, with 2-piece and a true engineered left/right airflow design. |
06-13-2020, 07:23 PM | #9 | |
Rep 3,748
Okay DD.... they not going to disintegrate on you. Replace together with pad... brand new everytime |
06-13-2020, 10:02 PM | #10 | ||||||||
Rep 206
I to no degree really know the total ins and outs with my car, i just know quality costs money. I haven't really shortsided anything on my car and id prefer not to, but some of these brake systems are veryyyyy expensive. My car is an m-sport but not quite sure if there is or isnt the upgraded brake system. If I replace one axle id prefer to do both but id also prefer not to spend $2k. At the end of the day im not tracking the car, its a daily driver, id just like to stop without squeaking. Cosmetics are always nice, i just compromise efficiency for looks. I just drive the damn thing lol. If i were to go with R1, would the Carbon GEO be a good set to buy or am i going a bit too dramatic? Im not opposed with going e-ljne instead, a difference of $300 is still saving $300. I have learned a lot on this forum and im continuing to, in baby steps. I appreciate all of your knowledge very much!
06-14-2020, 11:44 AM | #11 |
Rep 2,036
Any pros/cons to this combo from the gurus on this thread?
I have a 2016 F25 with original OEM brake/rotor setup. I don't track/autocross my SUV........er .....SAV. BMW Brake Kit - Zimmermann/Akebono 34106879122KTFR from FCP Euro https://www.fcpeuro.com/products/bmw...4106879122ktfr
06-14-2020, 12:00 PM | #12 | |||||||||
Rep 1,827
Otherwise, Brembo or StopTech would be a step in the right direction. Zimmerman I believe is OE. Money no object: https://www.ecstuning.com/b-ecs-part...09607ecs01akt/
06-14-2020, 12:21 PM | #13 | ||||||||||
Rep 206
06-14-2020, 12:23 PM | #14 |
Rep 3,748
I recommend R1 concept because the OP want to keep cost low.... and his post had question about opinion on power stop.
I put both company on the same category. |
DreamerJoe242.00 |
06-14-2020, 12:28 PM | #15 | |
Rep 206
06-14-2020, 12:34 PM | #16 | |
Rep 3,748
Result could vary😏 Last edited by Gen13 F36; 06-14-2020 at 12:44 PM.. |
06-14-2020, 12:36 PM | #17 | |
Rep 206
06-14-2020, 03:19 PM | #18 | ||
Rep 1,827
06-22-2020, 03:26 PM | #19 |
Rep 461
I cannot for the life of me find cross drilled zimmerman rotors for my 2015 435i xdrive gran coupe with the blue msport brakes.
Do they exist?
2015 435i XDrive Gran Coupe M Sport 8AT - Track Handling Package - M Brakes - PS2 - VRSF Charge Pipe - VRSF FMIC - BMS Intake - JB4 with MHD BEF - AA High Flow Catted DP - BMS Meth Kit 70% Meth - TurboSmart PB DV - MST V2 inlet - xHP Stage 3
06-22-2020, 05:30 PM | #20 |
F36 GC
143
Rep 259
If you aren't partial to the Zimmerman rotors I would recommend the Stoptech Drilled rotors. Just installed a set on my 2015 435 GC M sport and am very pleased with them.
06-22-2020, 07:01 PM | #21 | |
Rep 461
Not necessarily partial to the Zimmerman. I was looking at them more so because I'm having trouble finding a place with the Stoptechs in stock. Where did you buy yours? How long did it take to get them? I am getting a shudder felt in my steering wheel when I brake. I am assuming it's the rotors. Anything you thing could cause this? Wheels are aligned and balanced. Shudder only when braking. I'd rather not wait a month to receive new rotors if they're the culprit. |
06-22-2020, 07:19 PM | #22 | |
F36 GC
143
Rep 259
I bought mine at https://www.buybrakes.com/ Took about a week to receive them. |
