F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Ohlins BMS MP00 coilovers
Extreme Powerhouse
      05-19-2020, 06:38 AM   #1
B50AteYourRide
a bit obsessed
Drives: '16 340i x Drive
Hi,
I had looked at Ohlins coilovers in the past and found that they did not fit on X drive cars. Today I was browsing Extreme Power House and saw a new showing for Ohlins BMS MP00. I checked the Ohlins website and it does not say anything about only being for X drive cars.
Does anyone know if this is a new offering by Ohlins that does fit x drive cars?
Thanks
      05-19-2020, 10:47 AM   #2
FaRKle!
Drives: 328d Wagon, M2 Comp, i4 eD35
That's just the RWD PN. No xDrive version.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      05-19-2020, 10:59 AM   #3
B50AteYourRide
a bit obsessed
Drag. Wishful thinking. I tried ECS Tuning a few minutes ago and it came up as not fitting. Thanks for the reply.
Trying to find some coilovers. I have Bilstein in other cars/trucks and I had KW Variant 2 on my last “fun car”. Wanted to try some Ohlins, everyone speaks very highly of them.
Probably down to KW Street Comfort or Bilstein B16 Comfort.
I saw a thread about the KW Comfort and Ohlins offering a “flat ride” characteristic.
Is that still accurate, and what specifically does that mean?
I thought I knew stuff.
      05-19-2020, 11:36 AM   #4
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
What is your suspension lowering target?
I've had very good experience with KW Street Comfort coilovers in the past.
      05-19-2020, 11:48 AM   #5
B50AteYourRide
a bit obsessed
Modest lowering goals. The car has the M sport package, but I still find it a bit soft. Stage 2+ power levels, and getting aggressive, I would prefer less roll, dive and all that. If I want super smooth, or planning on rough roads, I’ll take the F-150.
I really liked the Variant 2 KW on the Legacy Spec b, but don’t need to get that low. I also understand x drive doesn’t respond well to extreme lowering.
This is all about performance.
      05-19-2020, 11:52 AM   #6
cfm56d7b
That's correct. Lowering xDrive vehicles too much can cause issues:
https://f30.bimmerpost.com/forums/sh....php?t=1640775
The reason why I liked KW Street Comfort coilovers is the ability to maintain near OEM suspension height if needed.
      05-19-2020, 01:39 PM   #7
FaRKle!
Here's a quick bit on flat ride (start at 0:37)
You can also use my new F3x suspension calculator to see what setups/spring rates will give you flat ride.
      05-19-2020, 01:58 PM   #8
eleven11
eleven11's Avatar
Drives: -F85 X5M-
I was originally planning to get Ohlins before learning they are not available with xDrive. I ended up with KW DDC coilovers, which allow you to adjust the dampening on the fly with the M Sport rocker switch (comfort, sport, etc.). I've been very pleased with them. My vehicle is a wagon (F31), but suspect they are great on all platforms.
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
f30post
