05-18-2020, 12:59 AM | #1 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
F3x Chassis Suspension Frequency Calculator, By FCM & FaRKle!
Shaikh at Fat Cat Motorsports convinced me to work with him on some suspension calculators for this BMW community. Our first version of a suspension calculator is out, and can be downloaded from the Fat Cat Motorsports' site (direct download link, "right click" and "save as").
This V1 calculator allows users to see what frequencies BMW factory and BMW aftermarket suspension configurations produce across the F30, 31, 32, 34, and 36 chassis. Additionally there's a "custom setup" output where users can enter whatever spring rates they like, and use either preset weight/weight distribution values or enter their own. I also included aftermarket suspension options that I had in my database for reference. Expect more versions of the calculator in the future with expanded feature sets (such as sway bars and roll couple).
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 02-28-2023 at 04:30 PM.. |
24
Sonic440i36.50 andino479.50 kpgray333.00 Jvac432.00 sewhelan934.50 B50AteYourRide70.00 cfm56d7b5886.00 brigade24156.00 exE36M3487.50 kreuz44.00 Wai328135.50 nadefade10.50 draggy29.00 johnung4528.00 skier_du147.50 Tommi_Mav65.50 CSBM52722.50 AmuroRay2282.50 otay826.00 gippy230.00 TSXforme6.50 gds4.50 mixmastermike55.00 dmanb2b2124.50 |
05-18-2020, 06:49 PM | #4 |
Rep 681
You can email KW to find out the spring rate info for those coils. They'll be different based on body style on f3x. Then you can plug those numbers in to figure out if they're what you're looking for.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
05-21-2020, 11:02 AM | #5 |
Rep 67
Thanks for this FaRKle! After reading many threads on the forums, I'm a bit lost on suspension upgrade options for my 2017 340i m sport (rwd/non adaptive). I'm looking for some drop (at least an inch over m sport), while maintaining comfort, performance, and a flat ride. Am i asking for too much? I'm open to coils or spring/strut combo, but having trouble finding spring rates on KWs and H&R springs since they're progressive. Based on your calculator, Ohlin's seem to be the best option for my purpose? I mostly engage in spirited street driving, but id like to open up the option to track the car several times a year. Could you guys help point me in the directionin the best options out there for my platform? It seems like majority are upgrading xDrive with adaptive from what I'm seeing.
05-21-2020, 04:16 PM | #8 | |
Rep 3,540
If you're looking to spend under $2k, you might want to look at one of the semi-custom options where you can spec your own spring rates like BC or Fortune Auto. I'm not sure how much they'll let you specify the damping you want though. If you're going to be spending above $2k, It's pretty difficult to beat going with FCM on a full custom setup built off of either a Bilstein B14 or H&R Street performance set as a donors. Since you're in the Bay Area, FCM is local to you too.
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
nadefade10.50 |
05-21-2020, 06:12 PM | #9 |
Rep 320
This is great! thanks Farkle!
BC is limited with damping they will do...whomever will have to do some persuading to get what they are looking for and even then they may not do it. |
05-22-2020, 12:19 AM | #10 |
Rep 67
Thanks for the responses! Are BC/Fortune decent quality options? I imagine they are entry level based on price point only. I've heard the BC name more than Fortune though
05-22-2020, 10:58 AM | #11 |
Rep 3,748
BC/Fortune is an entry level coilovers to me. Why it is recommended because they offer different spring rate on there coilovers or you can get a compatible spring to go along with them.
05-22-2020, 10:29 PM | #12 |
Rep 1,934
So if you get stiffer springs in the rear on any of the BC, or FA and the like, are you really doing yourself any benefit if the shock isn't valved to match?
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
05-23-2020, 12:03 AM | #13 | |
Rep 3,540
05-23-2020, 12:41 AM | #14 |
Rep 67
Couldn't you adjust the damper settings to match the selected spring rates if the company doesn't custom tune to your selection? Also, is there anyone running BC/Fortune cools with custom 4K/14K springs (or similar)? I'm curious on how the ride feels compared to something more mid/high tier
Edit: 4K/14K |
05-23-2020, 12:51 AM | #15 | |
Rep 3,748
05-27-2020, 06:00 PM | #16 |
Rep 1,649
This is awesome. Thank you for sharing with the community.
What about adding the M3 spring rates to the table for a reference point given I am sure the question of the rate comes up frequently and there are those of us running them on our cars? |
05-27-2020, 06:36 PM | #17 | |
Rep 320
I upgraded to 7k/20k swift springs and my BCs are on the softest setting when driving on the street. when i put in the swifts, the car's height increased in the back even though it was the same length of spring as the BCs i removed. For what I am doing, the rates are almost bang on! my car feels alive. but for a predominantly street machine, those rates might be a bit much. 6k/18k using a good quality spring I think would be ideal. my car is xdrive so that had an impact on my numbers when the spring rates were calculated. RWD can go stiffer in the front and softer in the rear, how much depends on weight/application/preferences. |
05-27-2020, 06:52 PM | #18 | |
Rep 320
loosening and stiffening sway bars had the same effect when I tested it. |
05-28-2020, 12:52 AM | #20 | |
Rep 3,748
05-28-2020, 03:29 PM | #21 | |
Rep 320
One reason why you may be getting the same numbers is because the mounting location of the suspension for both types of vehicles is the same. those suspension mounting locations is the information used to calculate motion ratios and hence, spring rates. the other part of that calculation is weight so again, not sure how you are getting the same numbers. You know what, I will plug in my numbers and post back with the results. You don't have power going to your front wheels so going stiffer upfront is less likely to induce understeer than with an xdrive. for example, there is a gentlemen on here who is RWD and regularly does HPDEs, he is on 8k/16k setup and is very pleased with it. |
05-28-2020, 04:34 PM | #22 | |
Rep 3,748
I could be wrong with my argument. Anyway I'll try to get a 4k/12k spring rate for mine but it will be awhile when I'm going to replace my suspension, probably end of this year or early next year. |
