05-14-2020, 06:03 PM | #1 |
Rep 40
Bounce Freq Calculator... attempt 2
After the inglorious failure of the last thread I decided to throw together my own calculator to share with the community.
https://docs.google.com/spreadsheets...it?usp=sharing You should be able to download it then make edits. So far it includes a bounce frequency/ratio calculator that can tell you if a set of springs/coilovers you're considering are an appropriate match for your car. For more info on this subject check out section 3 of this research article: https://www.ijera.com/papers/vol9no3...3036064%20.pdf I've started compiling a list of OE/Aftermarket springs and coilovers to compare using this method and I'd like continue populating it. If you know the rates or can take the measurements of a set of springs/coilovers to calculate them using the calculator in the top right of the excel please do and post your findings. P.S. Feel free to share this calculator as you like. Last edited by ryanjorunner; 05-22-2020 at 09:14 AM.. |
05-15-2020, 08:34 AM | #2 |
Rep 40
Update: Added a bunch of calculated rates for eibach pro kit springs and a lot of KW and Bilstein coilovers. Though, the Bilsteins seem to use a helper section on the rears that throws off the rate calculation. I'll have to do some research on how to account for that.
05-15-2020, 09:00 AM | #3 |
Rep 139
For dual spring systems, the total rate = (RATE 1 x RATE 2) / (RATE 1 + RATE 2) until the tender spring bottoms. You can calculate spring travel for both (load / rate = deflection) & switch over to just one when the other reaches its block height (= Number of coils - 0.25) x wire dia).
examples here -> https://eibach.com/us/p-108-eibach-e...tem-guide.html edit: selfishly (& for the benefit of F31 owners), could you make the corner weights &/or total weights + weight distribution modifiable? Or copy to a new tab which uses the weights from the C&D test sheet please? Edit 2: C&D test sheet -> https://drive.google.com/file/d/1M82...ew?usp=sharing Last edited by Neuner; 05-15-2020 at 11:47 AM.. |
ryanjorunner13.00 |
05-15-2020, 11:40 AM | #6 |
Rep 681
B14s spring rates are 399/565 lbs/in and they are most def in the pitch range. Not sure where you got the data but I don't think the data for b14s is accurate.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
05-15-2020, 12:00 PM | #7 | |
Rep 40
It lists the front spring part # as E4-FD1-Y226B00 with these dimensions: Wire dia: 12mm # coils: 6.7 Coil OD: 121- 95mm (I took an average of these ->108mm which is an assumption and source of error but can't lead to the rate being off by 1/2. If the full spring was 95mm OD it would still only be 303 lb/in.) So I plugged those numbers into the spring rate calculator and got 196 lb/in. I was just about to shoot off an email to Bilstein to try to verify. |
05-15-2020, 12:17 PM | #8 | |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Also, as you've found out, making assumptions about coil diameter leads to HUGE errors. IIRC Andino's data comes straight from Bilstein themselves, and I've seen other communications where Bilstein has said the same thing about this kit.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
05-15-2020, 12:26 PM | #9 |
Rep 40
Yeah, I'm concerned about the # of active coils as well. I can't tell if the pictures on each mfg site are of our actual springs or just some generic coilover so I didn't try to figure out active coils that way.
If anyone has a good source for any particular spring rate I'm happy to update the spreadsheet, I was just trying to avoid plugging in #s with no source or method of measurement given. I guess I was also trying to give Bilstein and KW the benefit of the doubt that they wouldn't sell coilovers with such horribly mismatched spring rates for our cars. |
05-15-2020, 01:38 PM | #13 | |
Rep 681
I forget which PN is rwd and which is xdrive but the rates and things are same regardless so it doesn't particularly matter unless you're buying for your car. The specs are identical across f3x/f2x regardless because Bilstein is lazy af. (photo 1) 47-207233 old part number new part number 47-264625 (photo 2) 47-217522 old part number, new part number 47-264632 edit: oh I didn't scroll LOL.
2006 997.1 C4S |
exE36M3487.50 |
05-15-2020, 05:45 PM | #15 |
Rep 3,748
This thing is giving me a headache.
Sorry what do I need to calculate for, is it just spring rate? I'm interested on Tein flex z coilovers with EDFC for my car. According to their advertisement sheet it springs are F: 6kg/mm and 10.6kg/mm That's about 336 lbs/in and 594 lbs/in. |
05-15-2020, 06:05 PM | #16 | |
Rep 40
For those rates It spits out a bounce ratio of .83 which is well into the pitch range. That means those spring rates on not well suited to that car. |
05-15-2020, 07:08 PM | #17 | |
Rep 681
That's like a really high level of what the bounce freq ratio is for. This is purely for spring rates only but doesn't take into account bump stop stiffness/engagement or sway bars yet. There's lot of info on this stuff by Farkie as well as on youtube from Fat Cat Motorsports who really goes into depth. I'd recommend checking all the resources out if you want to understand how it all fits together.
2006 997.1 C4S |
05-15-2020, 09:42 PM | #18 | |
Rep 3,748
Like everyone paying attention to this thread... ideal suspension is going to cost more because there is no out the box coilovers will pass this calculator. I am just trying to decide on a coilovers that is close enough to the ideal numbers. |
05-16-2020, 01:36 AM | #19 | |
Rep 3,540
When I'm done and this is released it'll be available for download for free from the Fat Cat Motorsports' site.
kilogram70.00 |
05-16-2020, 08:50 AM | #20 | |
Rep 40
Right now the only viable options in my mind are in no particular order: M-performance (nice mild upgrade but no adjustment) Ohlins R&T (still not ideal ratio and spring rates are too high for me) KW Street comfort with lighter 2039 front spring and 1 step heavier rear (still looking into feasibility) Hit up our newly introduced forum member Shaikh from Fatcatmotorsports for some modified Bilsteins + custom spring rates |
05-16-2020, 11:59 AM | #21 | |
Rep 681
2006 997.1 C4S |
05-16-2020, 01:30 PM | #22 | |
Rep 3,748
Seeing your getting all this separate .... can you give a ballpark cost you spending if this are new parts. |
