F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Alignment Issues, Front Camber
Studio RSR
      05-09-2020, 02:57 PM   #1
HLJustin
Drives: 2017 Alpine White 340i
So just out in new set of wheels and had alignment done. For whatever reason front right camber is super off vs left camber.
I'm lowered on Bilstein B16's and they matched before. What would you is possibly causing miss match? And what's best way to fix it?
      05-14-2020, 01:05 PM   #2
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
Are you sure they were the same before lowering? And are the front springs seated properly? Typically it's due to one side being lower than the other.
Originally Posted by umizoomi View Post
As long as 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
Youtube/Instagram/TikTok: @kern417
      05-14-2020, 01:56 PM   #3
HLJustin
Yeah, here's sheet from last year in January. Only thing that has changed since is new wheels. Was done at same shop too.
      05-14-2020, 02:28 PM   #4
kern417
Cheapskate
4450
Doesn't really make sense. If you lowered it, you shouldn't have less camber than before. I'd check the front left coilover and make sure everything is seated properly. measure how high the fender is from the ground on both sides to make sure it's even.
f30post
