DIY: Vorsteiner CF Trunk
09-13-2008, 11:44 PM | #1 |
Rep 4,737
Note: I would highly suggest buying the following parts instead of transferring from your OE trunk:
1) Badge 51 14 7 146 051. No grommet needed as the badge already has double sided tape included 2) Stop buffer: 51 71 7 162 385. Use double sided tape to mount. 3) Expanding nut for license plate holder: 51 12 7 020 321 ------------------------------------------------------------------------- 1. Mount the new trunk -- Partially attach the upper screws so that you can "hook" the trunk onto the hinges. Slightly tighten screws so that the trunk is not loose. Close trunk and check for fit. Adjust the trunk as needed. 2. Insert the wire harness. Install stop buffers. Install expanding nuts for license palte. 3. Install lights. Could be tricky because the CF sheets may be thicker than OE. Do it carefully. 4. Install license plate lights and trunk switch. Note: plate lights in pictures are installed wrongly. Should be turned 180 degrees. 5. Install the latch and key catch (drill mounting holes as needed). 6. Install white wire retainer. 7. Check all electrical components and mount wires. 8. Install carpet. 9. Install badge from outside. Place badge on trunk to check fit, you may need to correct the mounting holes. -------------------------------------------- good references: http://bmwfans.info/original/E92/ - for part numbers http://www.bimmerfest.com/forums/sho...d.php?t=254181 - for remvoing trunk. http://mileoneparts.com - order parts online |
09-26-2008, 01:34 AM | #3 |
chris
278
Rep 12,144
wow this is awesome! thanks for the write up... if i ever do my own trunk lid install, i'll be using this.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
05-10-2009, 12:37 PM | #5 |
Rep 4,649
oh by the way, you might want to have a dremmel handy...i had a few areas where the components didn't fit and had to sand down ever so slightly. mainly, where the trunk opener switch is. also, it is not necessary to drill the roundel post holes out. all i did was 3m tape the roundel on. my logic is the fewer holes, the better.
05-10-2009, 12:40 PM | #6 | |
Rep 2,558
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
05-10-2009, 12:49 PM | #7 |
Rep 1,389
Or if you don't have a Dremel, a round file and triangle file will do the trick.
I picked up this set from my local AutoZone for like $8. Worked wonders for all the the areas that needed adjusting.
"SYONRA" is for sale! http://www.e90post.com/forums/showthread.php?t=366678 BSM '09 e92 335i | Performance: JB3, RR Catted DP's, INJEN DCI, Britalman Exhst, AA FMIC, FORGE DVs | Suspension: ST-V1 Coils, Hotchkis Chassis Brace & F/R Sways | Wheels: Bremmer Kraft BR03s, Brake Performance Rotors, Cool Carbon Pads, ECS Lines | Exterior: OEM Aero Lip/Rear, ****** CF Trunk Lid, BLUX5 Angels, M-Force M3 Sides | Interior: Passport 9500ci, Black Trim, M3 Wheel
06-12-2010, 01:24 AM | #8 |
Rep 911
Op,
2) Stop buffer: 51 71 7 162 385. Use double sided tape to mount. from the time you done this, has the double sided tape kept the "stop buffer" in place? i was thinking if i need to get expanding screws to hold it in place instead. |
04-25-2012, 09:37 PM | #11 |
MATTE
47
Rep 515
are the part #s for those first three things the same for an e90?
Full Mod List: http://www.e90post.com/forums/showthread.php?t=647519
A-RAM WRAPS- VINYL WRAPPING SERVICES IN HOUSTON http://imageshack.us/g/818/dsc02742e.jpg/ Matte Frozen Grey e90: http://www.e90post.com/forums/showthread.php?t=709625[SIGPIC] |
