03-26-2020, 10:13 PM | #1 |
Rep 179
Painting Calipers, do I need to bleed the brakes?
I've seen how to disassemble the calipers and take them completely off the car on youtube, looks straight forward. The deal is I'll be disconnecting the brake lines as well and sensors. Now I'll cap the brake line, but do they need to be bleed after?
Thanks |
03-26-2020, 10:23 PM | #2 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Absolutely.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
sspade2466.00 |
03-27-2020, 12:08 AM | #3 |
David
786
Rep 2,009
Yes and don't run the brake fluid reservoir dry. You can use a stick or something to depress the pedal against your seat, that way it won't leak much once disconnected.
03-27-2020, 02:40 AM | #6 | |
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
03-27-2020, 08:28 AM | #8 | |
Rep 16,088
I hung the calipers from the springs with a section of coat hanger wire, masked off the undercarriage from over-spray with newspaper. In the two years since I've touched them up without removing them when I had the wheels off to rotate the tires. I used the same paint to do the rotor hubs. This is what they looked like a week ago, five months after the last time I touched them up. |
johnung4528.00 |
03-27-2020, 08:39 AM | #9 |
Modder of everything I own
147
Rep 491
I painted mine on the car without disconnecting, turned out great! Masked the shit out of it!!
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
sspade2466.00 |
03-27-2020, 11:26 AM | #10 | |
GasCompressor
333
Rep 564
I have used this G2 Caliper Kit, it does a great job! My 2014 335i was painted gloss black and retained its glossyness without pealing or chipping for 4 Michigan winters! I just pulled the wheels, masked the discs and other items and go! Just must have all wheels removed and be ready to apply to all calipers at same time. When you get done with first coat it is time to apply second coat to the first caliper. I will do same to new 440i as soon as weather warms up!
2022 Porsche 911 Cabriolet Agate Grey/Black PDK 2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold) 2014 335i M-Sport Black/Beige MPPK/MPE (Totaled) 2013 328i Sport xDrive Imperial Blue/Grey (Sold) |
johnung4528.00 |
03-27-2020, 04:14 PM | #11 |
Rep 2,806
Drives: F33 430 and F39 M35i
i didn't really mask off too much. painted easily enough.
didn't even mask off the clip. just masked off the rotor. |
03-28-2020, 01:50 PM | #12 |
Rep 909
If you take your time masking with painters tape, and trashbags you can get just as good as a finish. Might be a little more of a pain getting hard to hit areas but I just bled my brakes a week ago so I don't feel like re bleeding them already when i paint them in two weeks
03-28-2020, 06:18 PM | #13 | |
Rep 3,748
03-28-2020, 09:03 PM | #14 |
Rep 16,088
He said that he was removing them, true, but if the reason for removing them is to paint them there's no need for it. If he removes the lines then he has to bleed them, adding an unnecessary step.
03-30-2020, 05:52 PM | #15 |
Rep 179
I ended up just doing spot touch up for the chipped paint, thought it would be a better use of my time.
Worked out pretty good: I also removed the black paint from where the rotors touch the rims (paint gets all chipped there and looks awful. |
chowser512025.00 |
