03-09-2020, 09:15 PM | #1 |
Rep 3,022
Drives: 2019 M2 Competition
M Performance calipers plus R1 Concept rotor upgrade DIY
Hey yall!
I wanted to share my latest DIY with the community for my F32, including a couldnt pass up deal on calipers from a donor M4, R1 concept rotors and stoptech stainless steel brake lines! Since they were off anyway, I went ahead and had a local shop fully powder coat them for me, plus new ///M stickers! That way I get red that matches my car accents, and didn't put on beat up blue calipers. They were a little rough.. look amazing now! Let me know what you think!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
03-09-2020, 09:17 PM | #2 |
Rep 3,022
Before... and after!
03-14-2020, 09:26 PM | #3 |
Rep 10,256
Nice outcome. Well done and thanks for sharing.
BMW DIY Guy3075.00 |
03-15-2020, 12:34 PM | #4 |
Rep 47
03-15-2020, 04:26 PM | #6 |
Rep 3,022
Really happy with the upgrade! I will have another set available in about 10 days.
03-15-2020, 05:01 PM | #7 |
Rep 47
03-24-2020, 09:02 PM | #8 |
Rep 3,022
Absolutely loving this upgrade in my car, both in performance and in appearance! HUGE upgrade!
The only thing "left" would be the F10 M5 400mm front upgrade.. but that would crazy!
03-25-2020, 04:57 PM | #9 |
Rep 340
you mean like these brake caliper?
2016 435i GC - FBO - PS2 - XDI-35 hpfp - Stage 2 lpfp - M performance LSD -Custom tune BM3 w/ MHD monitor - xHP Flash stage 3 - Valvetronic Design Exhaust
03-25-2020, 06:47 PM | #10 | |
No 55mph
1622
Rep 8,476
If your pedal hits the floor then the system was not properly bled - nothing to do with coding or not I have had m4 brembo setup 370/340 on my F32 for years and did not code the brakes with absolutely no problems or reduction in braking Many others have not coded also. After the fact, I was actually told by BMW tech that they do not bother to code the perf brake option install if they are replacing the gray brembo 340 front systems as it is not necessary If you feel comfortable coding then by all means do it
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
03-25-2020, 06:50 PM | #11 |
No 55mph
1622
Rep 8,476
You happen to know if that kit fits AWD?
03-25-2020, 07:44 PM | #12 |
Rep 3,022
Not sure why it wouldn't.. I have talked with R99 (the original thread author) about this upgrade, certainly not cheap that is for certain.
Is the hub or knuckle area different on the AWD?
03-25-2020, 09:32 PM | #13 |
Rep 681
Yes the hub is different to accommodate the halfshaft. Though, IIRC R99 didn't need to use the m car hub to make his work.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
03-26-2020, 04:01 PM | #15 | |
Rep 47
03-26-2020, 04:24 PM | #17 | ||
No 55mph
1622
Rep 8,476
and I stated exactly what you are saying in my post: Quote:
04-07-2020, 01:38 PM | #19 |
Rep 619
04-24-2020, 09:24 AM | #20 |
Rep 3,022
Exactly.. thanks for sharing that info!
