MHD Stage 2+ E30 V9 Log Review
03-04-2020, 10:35 AM | #1 |
Rep 137
Drives: 2008 BMW 335i
Please help. I've posted it in the general "take a look at my log" thread but not really receiving any guidance.
I have a well maintained e90 N54 Auto (XHP stage 3) with new fuel system (stock), index 12's, fresh eldor coils, 1 step colder plugs gapped at .22, DCI, downpipes, intercooler, charge pipes and bov running MHD Stage 2+ V9 E30 map. this is my first tank of ethanol, I verified the e85 at the pump so I know its true e85; I had about a 1/4 tank of 100 octane in the tank and added 5 gallons of E85 and the rest CA 91. Flashed the e30 map and have done a couple pulls. My most recent one is below however my first someone said I was having too many timing corrections, can someone please provide some guidance? Much appreciated! https://datazap.me/u/bmc-83/e30-log-...27-28-29-30-31
2008 JET BLACK E90 335i
03-04-2020, 01:21 PM | #2 |
Rep 1,245
first off, holy shit dont try and look at that many pieces of data at once.
second, you need every cylinder timing correction logged. youre logging every cylinder total timing and its not necessary. just look at timing corrections for all 6 and then log cylinder 1 for total timing. do you have flex fuel? if not, you dont need to log ethanol content. your short terms are a few % apart. might be time for new o2 sensors all around. i will say, your fuel pressure looks fine. from what I can see it seems to be pretty healthy. getting some timing corrections around the shift, but with stock or xhp trans tune thats pretty normal. aside from that its hard to tell much. get your logging parameters cleaned up and id also advise to log with the fuel you'd normally run(91 + ethanol) not with 100 partially in the tank. then try again.
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50 11.61 @ 117.5 New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets |
03-04-2020, 03:02 PM | #3 | |
Rep 137
03-05-2020, 04:09 PM | #4 |
Rep 137
03-06-2020, 09:31 AM | #5 |
Rep 1,245
It is ugly for sure. Id up your ethanol content 10% or more and try again. Your fuel pumps are fine so it shouldn't be an issue to run heavier E.
03-06-2020, 10:15 AM | #6 |
Rep 137
Will go up to E40, new twins and port injection going in next weekend along with Custom Tune.
03-06-2020, 10:34 AM | #7 |
Rep 1,245
I wouldnt even worry about it then, id start running the fuel you plan to run with that setup and make sure you get your base file from your tuner before you install.
