E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > e90 roof bars - roof channel protectors
      09-09-2008, 12:48 PM   #1
palmyra08
Drives: 320d SE, 2008
Hi,
bought BMW-made roof bars for the E90 second hand on eBay. Right... Now to my joy, the manual says there are 4 'roof channel protectors' with L/R markings and a spring, which go under the roof bar at the mount points. The slight hickup is that they are not in the box........
Does anyone know if the lack of these 'channel protector' plastic bits means that installing the roof bars will do damage to the mount points? as it will be metal on metal... considering maybe some rubber strips instead as a diy solution.
Any ideas? much appreciated.
      09-09-2008, 03:14 PM   #2
Brussles 328i Owner
Drives: 2008 328i
I would suggest that you purchase some double sided tape from a local walmart, and then cut either a rubber strip or some sort of plastic strip. The stip needs to be no longer than one half inch wide. My personal recommendation would be the plastic strip, since this would protect the metal portion of the frame better.
Hope this helps.
Tags
carrier, mount, roof, roofbars
e90post
