02-22-2020, 09:38 AM | #1 |
21st Century Horse Rider
64
Rep 114
Standard suspension to M Sport suspension
Car is a 2017 330i M Sport that has standard suspension.
What parts need to be changed for converting the standard suspension (S225A) to the M Sport suspension (S704A)? Have any of you done this conversion? Feedback appreciated. |
02-22-2020, 10:15 AM | #2 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
How did you end up with an "M-Sport" that doesn't have S704A?
M-Sport suspensions have stiffer springs, dampers, and larger sway bars.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
johnung4528.00 |
02-22-2020, 10:54 AM | #4 | |
64
Rep 114
How I wish they left the "M Sport" models untouched... |
02-22-2020, 10:55 AM | #5 |
64
Rep 114
02-22-2020, 11:14 AM | #6 |
Rep 5,394
Drives: 2015 BMW 335i x-Drive Auto
IMO it wouldn't make sense to do that unless someone handed you the used BMW parts for free/cheap and you do your own labor. Otherwise it's less costly and you'll achieve a much better result by choosing the best aftermarket components to form a suspension system that best meets your needs.
02-22-2020, 11:33 AM | #7 | |
64
Rep 114
Dealer says only the dampers need to be changed. Springs and sway bars do not need to be changed. Sounds too good to be true. Would help if someone with the S704A option could provide part numbers for the springs and sway bars. |
02-22-2020, 12:13 PM | #8 | ||
Rep 5,394
02-22-2020, 12:47 PM | #9 |
64
Rep 114
Sounds good. Much thanks.
02-23-2020, 02:02 AM | #10 |
64
Rep 114
GetBMWParts is the site to go to.
Enter your VIN and it gives the part numbers for all types of suspension that the car can support. No need for an additional VIN. Great site. Last edited by phorge; 02-23-2020 at 06:25 AM.. |
02-23-2020, 10:22 AM | #11 |
Rep 4,333
With all this effort to obtain a 704 suspension, you should consider the M-Perfomance suspension, which lowers the car 20mm from base and 10mm lower than 704. Although its slightly firm, there is a noticeable handling and visual(reduced wheelgap) improvement.
02-23-2020, 04:13 PM | #12 | |
Rep 1,079
02-23-2020, 06:52 PM | #13 |
Rep 4,333
02-23-2020, 07:33 PM | #14 | |
Rep 1,079
02-23-2020, 10:00 PM | #15 | |
64
Rep 114
Only changing the shocks and springs. Not changing the sway bars. Will that be fine? |
02-23-2020, 10:38 PM | #16 |
Rep 4,333
Sway bars require removing the sub frame, very labor, thus cost intensive.
While the 704 is obviously better than the base, Its still not that composed during sporty driving. I'd rather do eibach springs with bilstein b6 or koni dampers |
johnung4528.00 MacklinUSOB518.00 |
02-23-2020, 10:45 PM | #17 | |
64
Rep 114
Might put off sway bar replacement. Just shocks and springs will be changed. |
02-24-2020, 12:44 AM | #18 |
Rep 4,333
the bmw parts and service department you are buying from and having it installed at, should have the part numbers for the 704?
FYI other than the part warranty, will your dealership honor a warranty for a 704 bought and installed elsewhere? |
02-24-2020, 06:18 AM | #19 | |
64
Rep 114
For some reason their system is not giving out the coil spring part numbers. |
02-24-2020, 07:23 AM | #20 |
Rep 10,256
Shocks and springs are considered wear and tear items. What specific warranty does BMW offer on OEM parts which were not however a part of the original build?
02-24-2020, 09:54 AM | #21 | |
64
Rep 114
Assuming you meant BMW, suspension warranty is valid if the installation is done with OEM parts at the dealership. |
02-24-2020, 11:48 AM | #22 |
Rep 5,506
You can buy msport specific aftermarket shocks from most vendors.
The spring part numbers are totally dependent on your configuration. BMW has many many different springs for the same car depending on what options your car has. I went through this with Farkle's help last year. I ordered new springs which was pretty pricey. My 328i with automatic transmission and RWD came out to be BMW part # 31336851921 front and 33536851930 rear. #31336851920 front may work depending on what your car is equipped with. I tried these -920 fronts and it was too soft for my car as it was fully loaded. With msport springs and shocks, it'll get you 80-90% of the handling of the m sport suspension. If you just want the m sport ride height, all you need is the springs.
Auto Detailing Enthusiast!
