02-13-2020, 03:07 PM | #1 |
Rep 741
KW v1
why would anyone pay extra for the EDC? (and is it worth it)?
thanks
2016 435i xDrive F36 M Sport - ER CP | ER Catless DP | VRSF 5" FMIC | bm3 stage 2 93 oct | black double slotted grill | AWE axle back exhaust w/102mm diamond black tips | 437m wheels
02-13-2020, 03:35 PM | #3 | |
Rep 741
edit: i mean the adap suspension.
02-13-2020, 03:51 PM | #5 |
Rep 741
i cant decide between the v1, v2 or comfort
coming from stock im pretty sure v1 is more than enough for me... i just want a stiffer ride (without losing comfort) and of course to bridge that disgusting wheel gap.
02-13-2020, 04:28 PM | #6 |
Rep 10,256
Did you explore KW Street Comfort coilovers as well?
02-13-2020, 04:30 PM | #7 |
Rep 741
yup its actually between v1, v2, and comfort.
02-13-2020, 04:56 PM | #8 |
Rep 3,748
Currently deciding on suspension too.. choices are
1. koniSA/ eibach 2. KW street comfy 3. Tein flex Z.... there not much to go on this one... no one has them on BMW. I might review it once my hook up give me a good price.😅 |
02-14-2020, 09:44 AM | #10 |
Rep 741
were those the only KW you've owned?
02-14-2020, 09:46 AM | #11 | |
Rep 741
kw comfort i have DEF heard good things about, but it is a few hundred dollars more than the kw v1, im trying to figure out if i need whatever added features it comes with. tein i know is a good brand however almost unheard of for this community to install in their cars... not sure why
02-16-2020, 05:59 PM | #12 |
Rep 1,079
I'm trying to find out the exact drop I'll get with Bilstein B8 paired with Eibach springs, if it's just 15-20mm in the front then I'll go with Kw V1, however minimum 1.4" drop in the rear with V1 is a bit concerning. My rear wheel gap is just 1.5- 1.6", however it is 1" extra in the front(~2.5 - 2.6"). xDrive front wheel gap is ridiculous, it's actually fine in the rear. I was about to go with Bilstein B14 as the minimum drop is pretty decent, 30mm all around however I keep getting mixed reviews, some say it's really good, some say it's really bad :|
SC is about $200 extra and I don't think I'll be fiddling with the damper setting, also to adjust it in the rear is not a simple process. EDIT: As you've already figured out, EDC cancelation kit only applies to folks with adaptive suspension, saves us about $200 |
02-16-2020, 10:20 PM | #13 | |
Rep 1,934
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
F36GC_NYC159.50 |
02-16-2020, 10:26 PM | #14 | |
Rep 1,079
Also the minimum lowering of 1.4" is a bit concerning. I would still have 5mm wheel gap as per my calculation Front minimum lowering of V1(1.2") is good, given that there is a huge gap. Did you end up getting SC? |
02-17-2020, 01:22 PM | #15 | ||
Rep 1,934
02-17-2020, 08:38 PM | #16 |
Rep 1,079
02-18-2020, 10:39 AM | #17 |
Rep 1,934
Still worth it imo. Buy it once and be sure of your satisfaction.
thatBimmerBloke872.50 |
02-18-2020, 04:12 PM | #18 |
Rep 1,079
You are right, SC will be the perfect setup. I'm trying to get the ideal setup without spending $1650 on SC, I'll also not be playing a lot with the damper settings. If I don't find anything then I'll probably have to just get the SC.
02-18-2020, 04:15 PM | #19 | |
Rep 1,934
They don't have access to anyone with xdrive in VA . Update: Nvm saw your sig
02-18-2020, 04:18 PM | #20 |
Rep 1,079
haha, I got their catalog in the mail today Even Koni doesn't have anything for F32 xDrive, Koni Yellow or SA with Dinan springs would've been an ideal setup too.
