01-03-2020, 03:14 PM | #1 |
Rep 3,654
F97 wheel on g05- Will it work ? (Thread)
Back story -
Had g02 with standard sport wheel. The plan was to just buy an msport air bag and throw on this wheel. Wild December Christmas bonus and good numbers from the dealer and I ended up with an msport x5. The plus- don't need to buy an airbag. Now I need to figure out how to swap out the trim and buttons. This should be doable. But definitely not plug and play anymore since my new car has the different driving assist options |
01-03-2020, 04:20 PM | #5 |
Rep 18,683
Straight forward swap.
Internals are the same, just multifunction button and trim are different. Oh, you'll need to move the top cover and M1/M2 button over too if you want to keep them there.
arciga181728.50 |
01-03-2020, 04:24 PM | #6 |
Rep 3,654
Woot woot. Seems like it's a job for tomorrow .
r33_RGSport12912.50 |
01-03-2020, 06:39 PM | #7 |
Rep 3,654
First update.
I started disassembly and realized I will need some tiny torx bits. Luckily I work at an industrial supply store and can pick these up in will cAll tomorrow . |
01-03-2020, 09:59 PM | #9 | |
Rep 3,654
Yes the buttons will likely be for show. Someone posted in the X3 that they found some settings on BimmerCode but I'm not holding my breath. Initially I was going from a standard sport wheel on an x4 and wanted the thicker "m" wheel. I loved the tri stitching and this wheel was local. So I pulled the trigger. |
01-04-2020, 10:20 AM | #10 |
Rep 5,724
Drives: '24 iX50; '23 i4 M50
You had to bring up my PTSD again with the fiasco many of us endured with the lack of m sport wheel on our first year X3 M40i!!
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
01-05-2020, 07:11 PM | #11 |
Rep 3,654
Ended up with this.
Sigh 😔. Might have to swap back and take it to dealer. Not sure what I broke. r33_RGSport What do you think I broke ? I also found out that my coding laptop is toast. ..... |
01-07-2020, 09:29 AM | #12 | |
Rep 18,683
What happened? You turn the car on without the airbag?
01-07-2020, 09:31 AM | #13 | ||
Rep 3,654
01-07-2020, 09:40 AM | #14 | |||
Rep 18,683
If it doesn't, you'll need to use ISTA.
