What kind of camera for HPDE/AutoX video and how where to mount? |
12-28-2019, 10:34 PM | #1 |
Rep 443
I'm looking to start recording my AutoX and HPDE sessions to go back and look for ways to improve afterwards and share just for fun. What are you using to capture track video and where do you mount it?
I've got a SeaSucker GoPro Mount, and am looking at a GoPro Hero 7 "Silver" as a simple enough camera with image stabilization and 4k/30fps video. Is the "HyperSmooth" image stabilization available in the GoPro Hero 7 "Black" worth ~$100 in price difference? Is there a different non-GoPro camera worth looking at? And where do you mount the camera? Is video better if it's through the windshield from the dashboard area looking out with a driver-like perspective over the hood? Should I mount it to the rear window so I can review my handwork on the wheel? Should it be positioned on the side of the car somewhere to give a good sense of speed?
17x9 APEX Arc8-R, 255/40/17 RE71RS, Vorshlag Plates, Swift Spec-R Springs, m-Performance Bumpstops, Dinan ShockWare, Paragon 2-piece rotors, Carbon lip, custom 3" alumalite splitter, GTS wing, FTP Intake and Charge pipe, BootMod3 Stage 1 OTS
12-29-2019, 11:44 AM | #2 |
Rep 819
Don't currently have a 2, but here is my favorite location.
Only real negative issue is that I have to replace the screen on a regular basis. I also have my dashcam mounted on the windshield, but I like the sense of speed and lack of obstructions from this location.
This post sent using 100% recycled electrons.
12-29-2019, 11:57 AM | #3 |
Rep 3,494
That's the place to mount it if improving your driving on a race track is the goal. All I use video for is to see if I'm placing the car exactly where it's supposed to be (and at the correct angle). Mounting the GoPro at the interior top of the windshield to the right of the rear view mirror captures what I need to see.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
12-30-2019, 10:39 PM | #4 |
Rep 442
get the 'black'
I would really recommend the 'black' versions of a GoPro. The key reason is that the black versions include a surprisingly good GPS, and accelerometers. The Hero5 Black I have is rated at 18hz, and is much better than my phone GPS. This data can be read for accurate speed readings by video apps like RaceRender. With the data integrated in the video file, it is super simple for RaceRender to automatically pull it out and use the GPS data in the video.
You can see the speed readings in this video: You don't need the latest GoPro. This video was done on a Hero5, which you can still find on close-out cheap. The Hero6 is starting to close out relatively cheap also. I also know some people who have good experience with a Garmin Virb. Don't forget to budget for multiple high-quality micro SD cards for the camera. At 1440 res I get just over 2 hours of video on 64GB card, which just covers the typical 4x 25m sessions of a typical HPDE day for me. YMMV, and higher res eats more space. I use a head-rest clamp for my camera. If you attach it to an occupied seat they are generally steady. I like to be able to see my steering inputs, and catch a glimpse of the gauges. Also really easy to power the cam from back power jack with a longer USB-C cable so don't have to worry about battery life. And easy to operate by just reaching back, and viewing it in the rear view mirror. This is the mount I use: https://www.amazon.com/Headrest-Tack.../dp/B00XIB6SK4 Still, I have been thinking about moving to a windshield mount. It definitely gives a better view of the track. Harder to power though, and mounts can be trickier. Some groups also have issues with just using a suction mount for a camera. They want it mechanically secured. |
12-30-2019, 11:00 PM | #5 | |
Rep 3,494
230iZTR315.50 |
01-09-2020, 10:05 PM | #6 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
I use a Garmin Virb and a cruise cam headrest mount
like this Video quality is good but the GPS data is not very accurate. I also recommend getting a case that allows you to plug in the USB charger while in use so you don't run out of battery. https://www.youtube.com/watch?v=p78OTx4KU2A |
01-11-2020, 05:32 PM | #7 |
Rep 442
I was going to point out to Nugget that you generally want to use a seatback camera mount only on occupied seats. If no one is sitting in the seat they tend to flop around and add a lot of shake.
But then I watched the linked video, and realized that he has a right-hand drive car, and that IS the seat he's sitting in. |
01-11-2020, 10:20 PM | #8 |
Rep 400
This is what I use to mount my phone.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 This is the video without a passenger on the seat. Not too bad. (also, wheel balance was not great during this track day.) |
01-12-2020, 08:28 PM | #9 | |
Rep 2,601
But the camera is actually mounted to the passenger seat in the video. I will try the driver's seat next time. |
01-13-2020, 10:21 AM | #10 |
Rep 322
This weekend I discovered rear-facing mounting on the rear windshield. Not as much for your own driving, but other cars you mess around with will love it. It does seem to convey a lot more of the speed feeling than the windshield or rollbar position.
Plus it makes a following car's mistakes (me, in this case) blindingly obvious: |
