DIY: E90 Andy's POOPER SCOOPER V1 ( RAM AIR )
View Poll Results: was this helpful? | |||
Yes!!!! Im gonna go to homedepot and make this now! | 36 | 62.07% | |
No, you suck andy. I'd rather sit on here and pick my nose | 22 | 37.93% | |
Voters: 58. You may not vote on this poll |
08-28-2008, 12:46 AM | #1 |
Rep 1,207
Drives: SG E90 325i sport + idrive
Garage List E90ANdy Lighting So ... [0.00]
cbv v bb [0.00] 06 E90 SG + M3 19&q ... [0.00] 06 E90 SG + Iforged ... [0.00] |
So, 1st day of college.. i missed my 1st class cause my 2am sleeping habit hasnt changed. So on the forums i somehow passed on the "air ram" or "scooper" with 3hrs do burn i did all the homework i could on the idea and after class headed to homedepot
I bring you "THE POOPER SCOOPER V1" by yours truly. SO.. to start off, you need some materials, i'll list what i used. - Home Depot 22gauge Steel sheet. 18" x 24" $8bucks - Heavy duty metal cutting sheers - Vise grip like pliers - Mechanix Gloves ( comes in handy so u dont cut yourself!) - Go JO Orange hand cleaner - Paper - Pencil - Measuring device (ruler or such) - Aluminum Level - Torx Bit driver - Flat head screwdriver - 4x 10mm bolts - 4x nuts for bolts - 2x Self tapping screws - Washers for bolts - Drill with metal drill bits - 6 pack of beer or capriSun strawberry - Socket wrench - Hi-temp engine paint, Pink is the optimal color - Poor mans Paint booth - Sand paper You WILL be using one of the Factory fasteners to hold up the Pooper scooper, however, for added stability i recommend making an additional bracket, like i did to hold it up @ hi-way speeds! Step One: Get your sheet of Metal and draw out the dimensions 8inch x 6inches. Cut it out. Then, on the 8inch side. Draw out a one inch width line vertically. Do the same for both sides. Now, starting from the top measure down two inches and make a mark. do the same, draw a line across the top 2inches down. See picture below. Step Two: Cut out the Light blue lines, as shown in the diagram. The edges are cut at roughly a 45degree angle. Sand down the sharp edges so u dont cut yourself This is where the gloves come in handy*** Okay, so with everything drawn out, cut and sanded; bend the two 1inch sides UP to form a 90degree angle. Now, take the 2inch section, bend it upwards to about 45 degrees or however u would like. i believe mines is around 45degrees or so. Ta da! you're halfway done. Honestly the hardest part of the whole project was cutting the steel, its hard as shit! but this helps for this 100+ wind speeds which everyone is used to heh. Step Three: Take off the stock intake duct. You do this by removing the 2 torx screws that are located on the intake duct. There are also 2 plastic pins that you will have to PULL out. Use your pliers and pull upwards until the plastic pins come off, then remove the bottom section of the fastener. Okay, with the Intake duct cover off do a mock up of how your POOPER SCOOPER is supposed to sit. Mines sit further outwards to the further edges of the opening. Btw. the 2inch section is the section that goes into the duct. and the 4inch section goes towards the grills. Step Four: Cut out TWO 1" x 3.5" pieces of steel. now.. Drill a hole in one end 0.5 inches away from the edge. This makes way for the screw. Okay next, Drill another hole at the other end. i'd say.. .5inches away from the other end also. Bend the piece of metal to form a 90degree bend as shown in the picture. Make two of these. Finger tighten everthing together as shown in picture. Step Five: REPEAT STEP 1-4 but drill the holes on the other side!!! Step Six Sand down, clean up your mess. Drink an icey cold beer because youre done with the "easy" part. Time for the mock up. Align everything and adjust brackets as needed so that the bolt holes line up to the factory air duct holes. Once everything is bent to the right place, tighten bolts. Now.. time for the fun part. PAINT! I chose to paint using Duplicolor ENGINE ENAMEL. It has ceramic so it helps with blocking the radiant heat of the STEEL scoopers. I used GLOSS BLACK because its not dull like matte black, but its classy, subtle yet noticable if you look. but stealthly at the same time. Step Seven: After everything is dry, personalize your Pooper scooper with whatever u want and make it look cool. I personally added afew drip paint marks to mines heh. its on the bottom so yeah.... anyway. Bolt up you scoops, re-install the air duct. take afew pics . Re-install the front grill and take for a test drive!!!! This mod should increase power as well as GAS MILEAGE! WHY? because it allows for cooler/ fresh air to come into the engine without it sucking it. Makes your engine more efficient therfore yielding more power, and overall improving gas mileage. Hope this helps!!! I posted pics of my finished product which i am very very proud of. Sure beats paying 100+ bucks, even though they might look better. But oh well, i used ALLEN key bolts so mines is super sexy too! Enjoy |
08-30-2008, 01:55 AM | #2 |
Rep 3,525
thanks for the great writeup, going to do this sometime when I am extremely bored
08-30-2008, 07:29 AM | #3 |
I'm feeling much better now, Dave
Rep 305
Pictures are worth 10,000 words.
Nicely 'worded' !!!
-=] 2008 335i e92 Montego Blue & Black; Prem; Sport; AT-paddles
-=] Mods= VEI Digital Boost Gauge in RiXeffects custom Pod -=] Tinted (front: 3M Crystalline 70); (rear: Johnson InsulatIR 40 ceramic); 3M ClearBra |
08-30-2008, 09:28 AM | #4 |
Rep 1,207
*bows* thank you, thank you
09-23-2008, 04:01 PM | #8 |
Rep 135
just made one myself today :P the factory fastner are kinda loose?? hmm but the self tapping screw hold it in place well , but not sure if i should change the factory fastner to something else?
Any wayz uplaoded few pic to share why waste 200 bucks when you can do this yourself and trust me i dont know anything abt cutting and bending and screwing lolz oeh forgot i think all this costed me less then 15 bucks. Last edited by MounisM; 09-25-2008 at 12:03 PM.. |
09-26-2008, 12:59 AM | #9 |
Rep 1,207
wow MounisM! for a minute i thought u were using my pics but it seems as if you have made an exact replica of my original pooper scooper! they look GRRREAT! lol, all the bends and such look awesome haha. enjoy the scoops! oh btw, if u listen carefully ( music off) u can hear more air sucking in whenever u hit the gas :P
09-26-2008, 10:30 AM | #10 |
Rep 135
E90, first off thanks alot for this idea saved me 200 bucks . Now i am thinking of buying an intake now not sure which one maybe injen?? anyway i dont think rain will effect the scoope right hmmmm let me know let me know
09-26-2008, 10:40 AM | #11 |
Rep 1,207
naw, i doubt it, i live in FL and i've had no problems.
09-30-2008, 03:49 AM | #12 |
Rep 767
THANX ******* , It took me about 3hrs to fabricate and paint the self made scoops..., I dont know about you guys but for my 318i, is a great improvement, also running a 'GREEN' sport air filter . Made them out of a plastic sheet that is ~0.3cm thick, black matt paint..... pics soon
THANK YOU ******* PS: I'm also concerned about the rain..., not that it will effect the scoops(I will make another set),but what if water gets to the air filter?
09-30-2008, 09:17 AM | #13 |
Rep 1,207
You could drill afew holes in the Crease section where the BEND is right smack in the middle. i would say.. 4x 1/4 holes should suffice. But yeah, the way i mounted mines it kinda sits behind the air hole, right on top of the airconditioning condenser thing (if u know what i mean) It makes like a little over lapping lip so any water would hit that lip and fly off not going into the air intake
11-17-2008, 12:20 PM | #14 |
Rep 602
Thank You Andy!
Great DIY write up very clear and inexpensive. Took some pics just to show the outcome.
,BMW 328i,Arctic Metallic,M tech,Ram Dinan CAI,Bmw Performance Exhaust,Performance spark plugs,Black Line,Euroswitch,Xenon Conversion with HID KIT from Halogens, 199- 19" Star spoke,InteriorTerra Leather,Premium Cold weather package,Led Lights.New> M3 spoiler, angel eyes harness,corner delete MOD,Lux h8.0, LCI 09 Xenon headlights,BMW Performance auto shift knob+boot,vinyl roof,Oem M3 220 wheels.
11-19-2008, 10:03 PM | #15 |
Rep 1,347
Drives: 2011 335d
This may be an incredibly stupid concept... BUT... has anyone experimented with curving the ends of the scoops that face the kidney grills along the bottom? Sort of like a plane wing? Wouldn't this create a bit of lift for the airstream and help flow? I'm guessing it would be so negligible it wouldn't matter but... I don't know. Might look cool...? haha
I'll be attempting this mod this weekend. Maybe I'll give it a go so you can all laugh at my stupid idea. |
11-20-2008, 02:03 PM | #16 | |
Rep 1,207
11-20-2008, 07:34 PM | #17 |
Rep 1,347
Drives: 2011 335d
Hm my buddy knows how to pipe-bend and has a welder. I would guess if I can use a blow torch or something I can get it to bend since he has all the gear for it. I'm gonna give this a shot and see how it turns out. Ill post pictures if it works out. If I dont post pictures... assume that I lost both hands in the process lol
03-08-2009, 09:57 PM | #18 |
Rep 3,031
Nice effort... I'm sure this does the same thing as the other ones, but it just looks so "home made" (stating the obvious here) to put on my BMW. I commend your efforts though! Good job!!
03-17-2009, 10:08 PM | #19 |
1 expensive toy
41
Rep 275
could you make these out of fiberglass? would there be too much heat for the glass?
i think you could mold some fiberglass, paint it, sand, and make it look real good. maybe just put a rubber grommet around the glass where the bolts go. any thought?
2016 F30 340i M-Sport
03-17-2009, 10:39 PM | #20 | |
Rep 1,207
OH great idea! HMM.. i have an idea thanks!!! |
03-18-2009, 08:03 AM | #21 |
1 expensive toy
41
Rep 275
does this mainly help stock intakes? what if you have a dci? would it push enough air into the bay for the cones to grab?
12-12-2009, 10:00 AM | #22 |
Cap'n Winky
23
Rep 172
So i'm thinking i could make up a few of these at work (1. laser cutting 2. cnc press brake 3. my CAD design)... anyone have an approx angle these are sitting at?
Guys, these really should NOT be $200 from anyone i bet with cad time and everything involved they have about $30-$40 in them. With resonable mark up they should be $80-100....NOT $200.... |
Turbo2Pete1.50 |
