Tire Pressure and Understeer
08-24-2008, 04:16 PM | #1 |
Rep 83
I have a 335i upgraded a Procede 3 and the Dinan Stage 3 suspension package that includes beefed up anti-sway bars, springs, shocks and camber plates. The shocks ahve been adjusted to their stiffest setting (12 out of 12). Wheels are OEM 189's with Eagle Assymetrics (255 in the rear and 235 in the front). Much of the understeer that is common with the 335i has been eliminated, but I still want the car to be a little more neutral. I have been searching the forum regarding tire pressure and some seem to believe that increasing tire pressure in the rear will help while others believe just the opposite. Last time I was at the track I ran 36 psi in the rears and 33 psi in the fronts. I'm going again tomorrow and need advice. Thanks.
08-24-2008, 04:22 PM | #2 |
Rep 26,878
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
Very nice set up!
I always like running higher pressure |
08-25-2008, 09:30 AM | #6 |
Rep 1,349
Look at treadwear patterns and you might want to borrow a pyrometer from someone. Sometimes less pressure is better too.
Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves. ~Albert Einstein
08-25-2008, 02:49 PM | #8 | |
Rep 122
Is the understeer on turn-in, or is it steady state? If it's on turn in, try a bit more toe-out on the front. Steady state, try more negative camber at the front. And I'd definitely try softening up the front shocks a bit. Out of curiosity, How does the rear shocks on full stiff affect putting the power down? |
08-25-2008, 07:39 PM | #9 | |
Rep 1,714
So do they: http://www.rogerkrausracing.com/Tech...verunder.shtml |
08-25-2008, 08:30 PM | #10 | |
Rep 10,509
I found a page that could be helpful to the OP http://www.miataracing.net/car_setup...g.asp#problems Also, I noticed the sixth row from the top describes what I intuitively thought (issue with damper settings) However, that page's advice is the opposite of what I recommended: "Corner exit understeer/ Front shocks are too stiff in rebound." ( I had suggested the shocks were too stiff on compression) My apologies to all for posting incorrect tech, and thanks leftcoastman for bringing to my attention Regards, Nick |
08-25-2008, 10:50 PM | #12 |
Rep 10,509
08-25-2008, 11:13 PM | #13 |
Rep 83
Thanks guys. I have been at the track all day and ended up running 41 up fron and 39 in the rear. These are after heating up. I will check in the morning to see what the corresponding cold temps are. I took off all of the traction control and the car was very well balanced. One of the instructors riding in a new M3 came up to me to find out what I had done to my 335 because I was right on the M3 in the corners and had more acceleration in the straights so that he had to let me by.
08-26-2008, 01:36 AM | #14 |
HYEPWR
99
Rep 2,868
what do you use as daily driving PSI? i have 32f 34r?
2002 330ci Titanium Silver / Gray
2005 X5 3.0i Black Sapphire Metallic / Black 2002 M3 Laguna Seca Blue / Black 2001 M5 Jet Black / Black |
08-26-2008, 09:24 AM | #15 | |
Rep 1,349
What he said. When my "cold" tire pressures were 32 up front and 35 rear they were running 41 up front and 40 rear when I returned from a 20 min lapping session. I had lots of push. I also had a treadwear pattern that looked like I had too much pressure up front. I took out 2 psi from the fronts and the understeer improved. 30 up front sounds right to me.
08-26-2008, 09:29 AM | #16 | |
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
This should help http://www.rogerkraustires.com/TechS...verunder.shtml wait..I just noticed that leftcoastman posted this already. BTW, leftcoastman..Brandon Kraus of Roger Kraus Racing/Tires use to do most of my alignments. I really like those guys.
Car is now gone .... :-( |
08-26-2008, 10:36 AM | #17 |
Rep 648
Your style of driving and speed at which you travel also comes into play with this variable. Some of you are reporting less push with less pressure up front and others less push with more pressure up front. The best advise is to adjust your pressures incrementally both front and rear and keep a log with times and comments to determine what is best for you. You will need to spend a whole track day on this with frequent hot pitting after a few laps for recording purposes. Most R compounds work best in the +-40lb hot range. I needed to start with about 26-28lbs cold to get there. However, I would recommend starting the first session with 32-34lbs and bleed down to the desired pressures. The 335 is front heavy and increases front temps more than some other cars. I will assume that your 33/36psi were cold temps and not hot. If they are hot, you are way to low especially in front.
As for my own recommendation, I always add pressure to the front to dial out push as I am starting with low pressures to begin with. With the DA's I would play with the front rebound and compression first rather than adjust the tire pressures as I had these adjustments available to me. General rule of thumb: increase front pressure and decrease rear pressure to dial out push, but I would do the front pressures first by a few degrees and then adjust the rears before adjusting the fronts any further. There is an interesting note in the web sites tire section under Toyo at the bottom: "Running 2# to 4# higher pressures in the front tires will reduce understeer in most cases". This assumes that you have good starting pressures. If you started with 45lb cold and ran over 50lbs hot, increasing pressure in front will increase push as there will be less bit in the front due to the decreased contact patch. The joys of tuning a car... |
08-26-2008, 11:31 AM | #18 |
Rep 1,349
A little off topic, but to illustrate a point, my TAG Kart will understeer slightly early in a race, then handle neutral, and then understeer some at the end again. What happens is the tire temps are cold and pressures are low at the beginning of the race, then tires warm up and pressures increase to where the contact patch is perfect and grip is great. As the race goes on the tire temps continue to increase, and the tire pressures get a little too high and the contact patch decreases. Guys will run Nitrogen to help, and/or adjust tire pressures so they're fast at the beginning, middle or end of the race.
So underinflation and overinflation can cause understeer, and it does depend on where you start for pressures when giving advice on dropping or raising tire pressures. Also, sometimes people think they have understeer when in reality they have improper corner entrance speeds, improper lines and improper braking (which I am guilty of). (Obviously using kart tires to illustrate a point may not be completely valid, but I think it helps.)
08-26-2008, 11:34 AM | #19 |
Rep 1,349
[quote=sg335;3227749]There is an interesting note in the web sites tire section under Toyo at the bottom: "Running 2# to 4# higher pressures in the front tires will reduce understeer in most cases". [quote]
I think this must be for normal driving tire temps (i.e., spirited road driving?). Right? If I had increased my front pressures my contact patch would have lessened further.
08-26-2008, 02:53 PM | #20 |
Rep 10,509
I use 32f/r cold pressure all the time, including DEs. I don't bother to play around with the temps since the car generally feels fine and I don't have a pyrometer (or suspension adjustability) anyway
I feel like the understeer can be minimized by backing off when the tires start to overheat (usually 15min into the afternoon session when ambient temps are 95F). That said, maybe I'm doing something wrong or don't have enough perspective, I find the stock car is fairly neutral and don't feel the need to change anything other than my driving skill |
08-26-2008, 10:31 PM | #21 | |
Rep 648
[QUOTE=DrDomer;3228081][quote=sg335;3227749]There is an interesting note in the web sites tire section under Toyo at the bottom: "Running 2# to 4# higher pressures in the front tires will reduce understeer in most cases".
08-27-2008, 08:27 AM | #22 | |
Rep 1,349
[quote=sg335;3231853][quote=DrDomer;3228081]
