09-23-2019, 05:24 PM | #1 |
Rep 14
M4 brakes on my F33 (420d SE from 2015) adapters needed?
M4's Brembo brakes on my F33 (420d SE from 2015), apparently custom made adapters needed?
I am new to this, would love some help from the pros out here. As preparation, I have already upsized my wheels from stock 17" to 19" to fit the M4 brakes which I luckily got from someone who decided to upgrade his brakes of his fairly new M4 (only covered 3000 miles). I was dumb enough to think they could fit right on, without doing too much research. And clearly they didn't fit. Apparently some custom made adapters are needed. Any thoughts and recommendation? Much appreciated. |
09-23-2019, 06:40 PM | #2 |
Rep 32,881
The calipers will fit straight on (they are the identical calipers which are in the F3x M Sport brakes) but you need to get 370mm discs to fit. The holes on the M4’s hubs are 10mm further out to allow these calipers to fit the 380mm discs.
09-23-2019, 06:49 PM | #3 |
Rep 117
So does that mean that all is required is to get the Fx 370 rotors to install them?
09-24-2019, 06:03 AM | #5 |
Rep 1,303
09-24-2019, 06:06 AM | #6 |
Rep 32,881
09-24-2019, 10:01 AM | #7 |
Rep 14
Thanks, the brake kit I got comes with 370 rear disks and front 380 front disks (very mean looking). Do you think its worth custom making the adapters for calipers to compensate the 10mm? Cheers
09-24-2019, 10:03 AM | #8 |
Rep 14
09-24-2019, 12:33 PM | #9 |
Rep 2,598
The 380mm don't fit - nor do the 370mm rears....
You may as well sell the ///M discs and follow the advice on here to purchase 370mm fronts and 345mm rears. There is someone I have seen on the FB groups that posted pics of 380mm ///M discs on his F3x but he did not post pics of the mounting solution and seemed to want to keep it guarded - not sure why, but maybe worth looking for the post and asking? I avoided the problem entirely and had brackets made to fit F10 M5 6pots with 400mm discs! |
09-24-2019, 04:56 PM | #10 | |
Rep 14
09-24-2019, 05:24 PM | #12 |
Rep 32,881
09-25-2019, 01:55 PM | #14 | |
Rep 14
Also are M4/M3 brake calipers definitely the same Brembo things as M Performance or M Sport calipers seen on other 3-4 series with M packages, which also have front 4 rear 2 pots, but with different colour variance? Cheers. |
09-25-2019, 03:25 PM | #16 | ||
Rep 32,881
09-25-2019, 03:29 PM | #17 |
Rep 8,500
That's what I'd expect as well, but I may be wrong.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
09-27-2019, 08:34 AM | #19 | |
Rep 14
He had to cut the brackets in order to mount the custom brackets so the the 380 and 370 ///M discs can be used. seems hard work. link to the post: https://www.xcar.com.cn/bbs/viewthre...2133263&page=4 |
09-27-2019, 09:32 AM | #20 |
Rep 836
Drives: F31 340i
Surely the simplest solution is just to buy the correct discs for your car? Straight forward bolt on upgrade over what you have then. Sell the part worn M discs to offset the cost a little
IK6SPEED4490.00 |
09-27-2019, 09:50 AM | #21 |
Rep 811
Not a chance in hell would I be using fabricated adapters to mount the calipers! Stick with a new set of discs or look at replacing the entire hubs. Hubs shouldn't be expensive, but you have to add M tax which will be undoubtedly astronomical!
IK6SPEED4490.00 |
09-27-2019, 09:55 AM | #22 | |
Rep 2,598
However, those brackets from China look rather dubious as it appears that the caliper body may have been machined to allow fitment |
IK6SPEED4490.00 |
Tags |
420d, brembo, f33 |
