2010 2011 BMW 5 Series Forum F10 2011 535i high pressure fuel pump issue |
09-19-2019, 10:57 PM | #1 |
Rep 26
Hello,
I have CEL "Drive moderately. Maximum drive train output not available" However it will be turn off when restart to engine. So I was trying to read OBD, it show high fuel pressure is too low and several cylinder is misfire. My symptom are - hard to start engine when in the morning - no power when press gas pedal - sometime engine is jerky I had recall service fuel pump last year and recently i took to bmw dealer. They have reprograming HPFP. However i have same problem. Anyone has same issue? I have planing to replace spark plug and ignition coil first then will replace HPFP.
Hi
09-21-2019, 06:38 PM | #3 |
Dream crusher
984
Rep 2,421
If you can check your rail pressure that's how you can tell. At idle you should be around 700 psi and at load around 2k psi
IG: @bmwdoubles |
ZeBoost1.50 |
09-21-2019, 07:48 PM | #4 |
Rep 1,299
09-21-2019, 09:59 PM | #5 | |
Dream crusher
984
Rep 2,421
This an n54 but I share the same pump as him.
IG: @bmwdoubles |
09-21-2019, 10:24 PM | #6 |
Rep 1,299
I got 2011 so I got the old n54 style pump. I am def. going to do the Helix overdrive unit plus full e85 fuel lines and run straight e85 and I already did the lpfp stage 2 diy. But not till next summer as winter is approaching in Chicago.
Going to get intake valves walnut blast during Helix install. Thinking of doing precision rw coils but I don't know... I need to do the custom intake too. Lol so much to do hehe. Last edited by ziekxq; 09-21-2019 at 10:31 PM.. |
09-21-2019, 10:32 PM | #7 |
Dream crusher
984
Rep 2,421
Current fuel pressure at cold idle
IG: @bmwdoubles |
09-21-2019, 10:38 PM | #8 |
Rep 1,299
Yeah mine is also 1000 - 1016 idle. I am excited to see your results... Maybe during winter I will build the custom intake and get precision rw coils. I just hope the auto can handle extra power lol.
09-21-2019, 11:53 PM | #9 |
Dream crusher
984
Rep 2,421
What's your wgdc at idle?
IG: @bmwdoubles |
09-22-2019, 01:39 PM | #10 |
Rep 1,299
09-22-2019, 05:58 PM | #11 | |
Dream crusher
984
Rep 2,421
This guy is pretty legit and he has a video of him making 500whp with the Helix.
IG: @bmwdoubles |
09-22-2019, 10:36 PM | #13 |
Dream crusher
984
Rep 2,421
Yes and i have a brand new OE one from FCP euro if you want to DM me.
IG: @bmwdoubles |
09-29-2019, 02:58 PM | #15 |
Rep 5,369
10-02-2019, 12:00 AM | #17 |
Dream crusher
984
Rep 2,421
Yes hit up Rob at Speedlogic he handles a lot of mods and repairs.
IG: @bmwdoubles |
10-02-2019, 05:55 AM | #18 | |
Rep 1,442
Drives: 2011 535i 6MT
That looks easy to replace at least. |
10-03-2019, 01:37 AM | #19 | ||
Dream crusher
984
Rep 2,421
- bad DV - wastegate not adjusted - bad solenoid - boost leak - bad tune - spark plugs not tapped down on a tune - IATs too hot pulls timing - coils going bad - MAF sensor - check engine light - fueling
IG: @bmwdoubles |
10-04-2019, 12:53 PM | #20 |
Rep 26
I replaced HPFP. I have solved problem.
Hi
Bmw doubles983.50 Romeo4.50 |
