09-18-2019, 01:16 AM | #1 |
Rep 251
Advice on tire size
I have ordered a set of 20x9 25offset 20x10.5 38 offset wheels
I would like to run a 285 in the rear or if possible a 295. what are the pros cons of running the wider 295 vs the 285 and what would be the recommended front tire size? Thank you in advance |
09-18-2019, 05:30 PM | #2 |
Rep 607
I run 20x9 ET25 and 20x10.5 ET35 with 245/35/20 and 265/30/20 because I am lowered. You could easily run 295 or maybe 305 on the rears if you are not lowered.
Life is short...Drive fast
09-18-2019, 08:19 PM | #3 | |
Rep 251
I would at minimum like to run 285 if possible but 295 would be ideal.. Your Car looks great! Well done |
09-18-2019, 09:04 PM | #4 |
Rep 1,062
Drives: i5 M60, M5's, 535.335, M550i
295's would look better than 275's the car comes with. I put 10mm in front and 12mm spacers on rear and I'm still looking for wheel well to be filled a little more in rear
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M , 2013 M5 , Individual Silver, Bolt ons-Straight piped 2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete 2024 i5 M60 Cape York Green |
09-19-2019, 05:41 PM | #6 |
Rep 1,062
No, stock 275's with 12mm spacers. I want to go to 295's since it's a minor increase in width but will still have a visual difference
09-19-2019, 09:31 PM | #7 |
Rep 251
09-20-2019, 06:16 AM | #9 |
Rep 607
09-20-2019, 08:43 AM | #10 |
THUNDER UP!
263
Rep 292
Yes, it would be okay. Just make sure your overall tire diameter (height of the tire) is consistent in the front and rear.
G30 l Alpine White l M Sport Package l Executive Tier l Icon Adaptive Full LED Headlights l Mocha Nappa Leather l Multi-Contour Seats l Drivers Assistance Package l Drivers Assistance Plus Package l Dynamic Handling Package l Parking Assistance Package l Bowers & Wilkins Diamond Surround Sound System l M Sport Brakes l Apple Carplay |
09-20-2019, 12:43 PM | #11 |
Rep 251
10-14-2019, 08:28 AM | #13 |
Rep 1,062
I can't confirm but 295/30's is what I want in rear but I have spacers and not lowered.
10-14-2019, 11:37 AM | #14 |
THUNDER UP!
263
Rep 292
Yes, those would be good choices. Just make sure your rear wheels will be at least 10" wide (so 20x10 in your case) for the 295 tire. Looks like you ordered 20x10.5 so that will be perfect.
You could technically run a narrower wheel like a 9.5" on that size of tire, but 10" is the minimum recommended wheel width for a 295 tire. Anything less than 10" on that tire will make the tires buldge which isn't ideal. Put up pictures when you get them mounted!
deepat0451.00 Jonathan G.9.00 |
10-14-2019, 06:05 PM | #15 | |
Rep 251
12-12-2019, 09:28 PM | #16 |
Rep 135
So, did you put 295/30/20 in the rear? Got any pics? My buddy selling a set of used 20x9 wheels and I'm thinking of buying them and fitting some continental tires in 295/30 also.
12-13-2019, 10:40 PM | #18 |
Rep 45
On my M550i I'm running 20×10.5 in the rear and 20×9 In the front with 275/35R20 and 305/30R20's. I had the 285's and 290's, but liked the look and ride with the these the best. No rubbing issues.
2018 M550i xdrive, DME Stage 2
12-27-2019, 09:49 AM | #19 |
Rep 412
Hi all and merry Christmas
I would like to know if someone has tried to put 265 front and 295 on OEM 20 wheels. I am going to buy a G30 540i rear wheel drive and would like to improve traction since I am looking for a stage 3 and hopefully more than 500hp. Thank you
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
12-31-2019, 10:58 PM | #20 | |
Rep 251
What are your wheel offsets? |
TexasM550i62.00 |
12-31-2019, 11:01 PM | #21 | |
Rep 251
This is the size to go with IMO Here are pictures without my floating OEM caps. |
01-06-2020, 10:38 AM | #22 | ||||
Rep 45
