09-11-2019, 06:13 PM | #1 |
Rep 525
440i on track, an amateur review
After a month of planning and research and some trepidation, took the plunge and decided to track the car on an EVO evening session at Bedford autodrome. I had 1 objective - to try and do skids, understand what the car was actually capable of at the limit, and shred the tyres. I've never had the chance to attempt skids before - I wouldn't dare try it on the public road - and finally here was an opportunity to live out my inner chris harris.
In the end I did 4x12 min sessions with about 15 min breaks in between, didn't fancy doing anymore given the brake issues (more of that later) Unfortunately I got the 'NO DRIFTING' sign held up at me about 3 times, so I've edited together all the ones I could get away with. Here are 2 vids from the day - first one is all the attempted skids cut together. 2nd one is from the 4th and final stint where I reverted back to a little more grip driving. Even with the grip driving I still found the car enjoyable, to my surprise. Annoyingly i forgot to mount my 2nd cam to record the dials, but i had my speed warning set to 90mph so if you look closely you can see the orange warning triangle light up whenever i hit 90. I also had in the back of my mind throughout "this is my precious car and it must get me home", so chose to short shift around 5500rpm each time. I regret not pushing it a little bit more now...wouldn't have done much more harm! I thoroughly enjoyed it. I didn't think i would as its something not designed for track use - the last time I'd driven a road car on track was in a 2016 Type R, and though it was far better sorted for track use than the 440i (excellent body control, flat cornering, stiff suspension) - it was wrong wheel drive. Managing understeer at apex and out of corners gets boring pretty quickly. What doesn't get boring, ever, is having a car break traction at the rear :-) The 440i was hilarious over the limit and made me giggle. I was finally experiencing the car properly after 16 months of ownership, especially with the MPPSK i'd fitted only a few weeks prior. A quick comparison with an M4C I also got to drive an M4C for 2 laps as part of the EVO magazine promotion thing. Obviously I only got a really short time to assess the car, so my perception of it is not going to be a conclusive opinion, however - - I was expecting a really stiff track orientated car, in the same mould as that Type R. Amazingly, I found the body control to be only slightly better than the 440i. It still felt a bit sloppy to me, with the same dead feel from the steering to accompany it. If I had spent £60k on one of these I'd be hugely dissappointed. - Wasn't as fast as I was expecting - the 440i was nudging 140mph on the back straight and I was reaching just over 140mph in this, obviously with longer track time and focusing on lines/exit out of the corner it would probably be closer to 150+, but given that this car has 100bhp more than mine, I was expecting more noticeable and significant oomph. - (to my ears) It didn't sound as good as my MPPSK'd car, i would say, significantly not as good. There doesn't appear to be any tone to it below 6krpm, though it did liven up past this. - The heads up display was really useful and I wish I had one in mine. (not sure if I can retrofit one…probably not). - The DCT was FANTASTIC and the standout feature. The racecar like jolt on the upshifts, and the instant response and blip on the downshifts was amazing. The ZF 8 speed is good enough, but cannot compare to this - not in the same league. I wonder what the new ZF's are like in the new M cars? I assume they've engineered them to be as good as the DCT they've replaced - I need to look into the ZF software hacks…. - It was nice having a progressive rear end. Palmersport had their regular instructors managing the BMW demo cars - I asked before jumping in if I could turn off the DST….he said no. But he did let me put it in dynamic TC after the first lap. Even with this half nanny mode engaged, I could feel the rear slip being much more easily controllable out of corners. The 440i's oversteer is like an on/off switch in comparison, although i'm sure with a bit more time and throttle control it could be tamed a little. Overall I found the experience underwhelming. My fear before driving it was finding it so much better than my car and trying to justify trading in for one - but its not the track weapon I thought it'd be, given the price. I'm now very happy with the amount of car I got for £27.5k. Future mods needed Now I've got the racing bug back it looks like I'll have to scrape the cash together for the following mods in readiness for the new season next year: - An M performance or Quaife diff. - A cheap set of wheels and tyres just for track days - the less grippy the better… - ZF remap for quicker shifts - Suspension that gives flatter cornering and better body control (no idea which suspension components I need to upgrade to achieve this, anyone?) - Performance rotors that can withstand the heat - see if there's any way to put in a seat with fixed harness which i can swap out easily after track days - Find some circuits with more opportunities to do skids. Issues The only issue I've had has been with the brakes. I've done something to my discs, and was experiencing it both on the journey back home and after swapping back to the OEM pads - I now have a vibration coming through (and a drone noise) as I brake through 40mph, from higher speeds. It remains from 40 down to 20mph or so. Not sure if I've warped the discs in some way, or maybe its just track pad material I need to remove, or get the discs reskimmed? if anyone has any thoughts or can offer suggestions I'd appreciate it if you could go here and respond, where I've made a thread specifically on the issue. https://f30.bimmerpost.com/forums/sh...2#post25240442 Conclusion if you have an x40i and haven't tracked it - do so, it is a huge amount of fun. Last edited by gippy; 09-11-2019 at 06:45 PM.. |
09-11-2019, 06:49 PM | #2 |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
Good videos and it looks like you was having a blast. Ive not Bedford in years, although I'm doing a bike day at Anglessey the weekend.
I can't really help with the brakes. Bets thing is to visually check the discs and maybe throw a set of pads at it to check.
09-12-2019, 05:30 AM | #3 | |
Rep 525
i'll have a look at reskimming but most likely i think i'll just buy some new OEM discs and fit em myself, and buy some performance rotors next year for track day use only. |
09-12-2019, 05:30 AM | #4 |
Rep 8,499
If you went to an EVO event to do skids, you went to the wrong event - as you found out.
This is precisely the kind of driving that isn't welcomed. EVO, and other organiser's, track events are all about smooth fast progress and good control. Trying to skid/drift, at the risk of losing control and risking damage to your car and others on the track is not what these events are about. You'll soon get plenty of looks from other drivers as they realise that you're a liability. I'm surprised you got to three 'no skid' flags. Normally they'll black flag you after a couple, and bring you into the pits for a stiff word. Carry on regardless and it'll be the end of your session.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
09-12-2019, 05:47 AM | #5 | |
Rep 525
and skids are so much fun was great to find out how the car handles in oversteer, everyone should try it. |
09-12-2019, 05:50 AM | #6 |
The artist formerly known as AC Schnitzer UK
3609
Rep 4,518
09-12-2019, 11:11 AM | #7 |
Rep 864
Nice writeup, looks like you had a lot of fun!
Find it a bit strange that you were willing to get the back end out, but not willing to rev it to the red line, or even the top of the powerband! With the brakes, did you make sure at the end of each session, (a) not to put the hand brake on, and (b) not to hold the car on the brakes if you needed to come to a stop, that wasn't where you were parking the car? After each session I did a cool down lap, then drove carefully around the car park areas, not using the brakes, then put the car in park/engine off in gear for a manual. If it's pad material, you could try doing some repeated high speed stops somewhere safe, but you may just need to get them skimmed/replace them. |
09-12-2019, 12:07 PM | #8 | |
Rep 525
yes and yes to your questions. i'm getting them skimmed at an F1 autocentre for £95...hope that fixes it, if not its £340 for a pair of discs. ouch. |
09-12-2019, 12:39 PM | #9 | |
Rep 271
Btw, where are you getting the replacement discs from, assuming you need them ? Price seems a little steep Last edited by seenthelight!; 09-12-2019 at 12:46 PM.. |
09-12-2019, 01:48 PM | #10 | |
Rep 525
i guess not! |
09-16-2019, 08:32 AM | #12 |
Rep 2,127
Good review.
I have driven the M4's they have at Bedford Autodrome. I haven't driven mine on a track, but I too felt that the M4 wasn't a massive improvement over mine in terms of speed in the straights and cornering compared to a few spirited country road corners in mine. I still loved driving it though and want to go again.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
09-16-2019, 01:06 PM | #13 |
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Glad you had a good time! Interesting read too.
I hope you've not fully warped your discs. I too found it strange that you didn't extend your engine, but pushed everything else! Given that you didn't extend your own car it does seem weird that the M4 didn't feel faster, as presume you dit take that to the red line? If not, then try, and then you'll feel the extra horses! The standard M4 damping isn't fantastic, so I've swapped mine out for coilovers, but the way the front end steers is night and day better than a standard car. The bushing is much stiffer, there's more camber, at the rear there is a solidly mounted subframe, so there's lot more precision, especially when you add in the M-diff.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
09-16-2019, 01:09 PM | #14 | |
Rep 19,982
The Palmer M cars have roll cages, bucket seats, coilovers, track tyres, big brake kits, and they're absolutely night and day better on track than a standard Mcar.
Abzynthe1387.50 |
09-17-2019, 07:00 AM | #15 | |
Rep 525
i didn't bother with insurance in the end - i got a quote from Moris for £140 odd i think it was... spent some time mulling over the risk vs cost and thought it wasn't worth it. I was really worried about random instances happening on track, i've seen so many nordschleife crash compilation videos.....but i was expecting the driving standards at an Evo event to be good enough, which they were - everyone was excellent and well behaved when around other cars. Also you'd have to be pretty incompetent to crash at Bedford. Maybe when i do more open pitlane events on other circuits i'd reconsider. Haven't got me brakes sorted yet, i'm pretty sure i've just got uneven track pad deposits, i'm going to switch back to the track pads, drive around for a few weeks and see if it improves - if not, i'll get them skimmed. |
09-17-2019, 07:13 AM | #16 | |
Rep 525
yeh, definitely it was that progressive rear that was the standard feature compared to my car (and that DCT) don't get me wrong, the M4C was certainly more precise, i was just expecting something a bit more raw. I've driven those palmersport M4's a few times back in 2017 - i haven't read car mags in a decade and knew nothing about the M4C - i think i was expecting a palmersport M4 type experience with less noise! An M4 with Type-R stiffness and steering response, i don't know Maybe the 'Competition' moniker is a tad misleading. As i say i only had 2 laps so my opinions on the car are by no means final at all, if i could afford it i'd get an M4 and stick on uncompromisingly stiff suspension on it |
09-17-2019, 07:19 AM | #17 |
Rep 470
Hehe let's hope you're still allowed to drive a 3.0 petrol engine in 10+ years!
Oh interesting re insurance - I read somewhere that you had to show proof of your track day insurance at these events! However was thinking that re that Bedford track looking newbie friendly - will give it a go after I get my MPPSK fitted next week! Annoying re brakes. Was reading somewhere that simply up-rating fluid and lines will reduce brake fade significantly, and maybe all the novice to intermediate track day 340/440 driver needs. |
09-17-2019, 07:29 AM | #18 |
Rep 70
Interesting write up. I had a 440i with MPPSK and whilst it is a great car for the money it’s night and day different to my M3 CP. My M3 is a different animal altogether. A 440i shouldn’t get near a well driven M car around a track. I think you needed a few more laps in the M to get your confidence and eye in.
09-17-2019, 05:41 PM | #19 |
Rep 9,709
No need to upgrade the lines. Modern lines are aramid reinforced. At around 3-4 times the tensile strength of stainless steel, there is no reason stainless would better. In fact many reasons why stainless are worse.
09-18-2019, 05:37 PM | #20 |
Rep 331
3-4 60mph to zero stops in quick succession will clear the vibrations . Happened to me all the time after track days
Current: F30 335d xDrive M Sport Plus
18" PZero - 405Ms - ACS Springs - Eibach 16mm ARB - Indigo GT Remap |
09-18-2019, 05:49 PM | #21 | |
Rep 8,499
Stopping the car fully with hot discs and pads increases the risk of uneven deposits.
BIFCAIDS857.00 |
09-18-2019, 08:14 PM | #22 |
Rep 2,639
I can confirm 40i lines are still rubber hoses, not aramid reinforced, which you should upgrade to stainless lines if you tend to do more lapping. If you also drive the car in the winter, normally the coated stainless steel lines will also protect the line from debris and such.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
