17" Square setup.. What offset?
08-19-2008, 02:26 PM | #1 |
Rep 2,896
Hey guys,
ABout to pull the trigger on the Kosei's 17x8.5 from Tirerack for a square track setup when I saw these D-Force LTW5 that I think look way better... They are 16 Lbs each and not that much more expensive than the Kosei.. They come in 17x8.5 ET 40 and I think 17x9 ET 41 .. Which is the best size and the correct offset for my E90 335 for a SQUARE setup with no spacers and no rubbing.. (Stock suspension not lowered) Thanks |
08-19-2008, 02:37 PM | #3 |
Modaholic
88
Rep 1,705
I remember reading that not all 17" wheels will clear the 335i front brakes... just make sure you do your research before buying.
Euro Delivery - April 2007
08-19-2008, 03:05 PM | #5 |
Rep 1,714
Test fit one at your next autox/track day.
If you look at the Koseis, the inside of the rims have this indentation that PERFECTLY fits the 335i brakes. It's so close that I always get rubber-booger marks on the inside of my rims. If the LTW5 doesn't have that, you're screwed. |
08-19-2008, 04:26 PM | #7 |
Rep 1,288
Drives: 135i
Just get the Koseis you can't ask for a better fit
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
08-19-2008, 05:14 PM | #8 |
Rep 2,896
08-19-2008, 05:21 PM | #10 |
Rep 1,476
uh yeah. But, you can run whatever rubber you want on your non-leased set of wheels.
I don't believe in that whole unsprung mass thing anymore. If I can't feel it, it isn't real! ________ Avandia death Last edited by satakal; 08-16-2011 at 06:00 PM.. |
08-19-2008, 05:23 PM | #11 |
Rep 1,714
08-19-2008, 05:27 PM | #12 |
Rep 2,896
I want go.. But if you can get good looking wheels that weight just as little actually a little less then the Kosei for just a little extra cash, then why not?
08-19-2008, 06:03 PM | #14 | |
Rep 1,476
The Kosei is a 17 that fits. The SSR 17 that the guy who won 6cyl stock at the autocross was trying to sell doesn't fit. the only rule of thumb to follow sounds like... "if the shoe fits, buy it." ________ Buy vapir vaporizer Last edited by satakal; 08-16-2011 at 06:00 PM.. |
08-19-2008, 06:52 PM | #15 |
Rep 2,896
Here is a link to these wheels in case anyone wants to see what they look like..
http://store.bimmerworld.com/shared/...t=products.asp They were also featured on the blue 135 in August edition of Roundel magazine |
08-19-2008, 07:10 PM | #16 |
Rep 133
Talk to these guys:
http://www.vorshlag.com/index.php?cPath=1_79_90
*Ultimate* mod for the car: a better driver...
08-19-2008, 09:19 PM | #17 |
Rep 1,288
Drives: 135i
There's no chance in hell that 17x9 ET41 wheel will fit without spacers or rubbing. I just put KW V3s on and my Kosei K1 17x8.5 ET40 (245/45/ZR17, -2.6 camber) is rubbing under full lock with the drop. Without the drop I think it was leftcoastman that mentioned there's a like...6mm space between the strut and the wheel, you'll lose that with the 17x9 ET41. In that case you'll need spacers which have a host of downsides over time.
I see no reason not to get the K1s especially since they're cheap as hell (IIRC $100 cheaper than the LTW5) and look one hell of a lot better in person than online. Leftcoastman is right, it's a question of go or show. The LTW5 and K1 look almost identical... I think the LTW5 is uglier but the fact is it doesn't matter. After one lap they'll be covered in dust and look like shit anyway.
08-19-2008, 09:21 PM | #18 | |
Rep 1,288
Drives: 135i
Unsprung mass makes a huge difference and if you look for it you'll notice. The car gets much more responsive moving from the craptastic stock wheels to aftermarket lightweights.
08-20-2008, 09:21 AM | #19 | |
Rep 1,476
I'm not gonna argue with a Newtonian equation. I don't need the bloody nose. I'm just saying that I saved 10lbs per corner with a new wheel/tire combo and my driving spidey senses aren't sufficiently sensitive to feel a difference. Ramos: those wheels are ugly. IMO. But, I've been wrong before. I think the C30 is hawt. ________ Live Sex Webshows Last edited by satakal; 08-16-2011 at 06:01 PM.. |
08-20-2008, 10:08 AM | #21 |
Rep 1,714
Yeah, like I said, I'll rub in the parking lot with Koseis and 255s. I have yet to experience full lock on track at speed, so no rubbing on track, lol.
THE BIG UNKNOWN WITH THE LTW WHEELS IS BRAKE CLEARANCE. It barely, barely fits with the Koseis. If the LTW doesn't have the same schpanky stepped design, there is no way it will fit. IF the brakes fit, a LTW5 17x9 ET41 with 5mm spacer will probably still work, even with 255. On the Koseis, the issue was that the wheel was getting close to strut - lowered or not doesn't make a difference there. The tires were fine. Deflection under cornering load generally occurs on the bottom half of the tire anyways and I never got "rubber" on my strut tube. With the Kosei, I had 6mm between strut tube and wheel. The 17x9 would protrude inwards an additional 6.35mm (1/4 inch) from the wheel width change and 1mm from the offset. That gets you 7.35mm inwards, which would NOT work without a spacer. With the 5mm spacer, you would be 2.35mm inwards compared to the Kosei, basically cutting half your clearance. That's too close for comfort in my mind. |
08-20-2008, 10:13 AM | #22 | |
Rep 1,714
But girls risk a lot when they wear high heels, right? |
