08-29-2019, 03:00 PM | #1 |
Rep 80
I am losing my mind...
Good evening,
My 320d (2015 /70k) has the strangest problem in that the steering kicks/notches/wobbles/reacts fairly sharply on long swooping fast bends. After hours/days of research about my issue, I took the car to a very reputable and decent indy who said it may be the control / thrust arm bushings as they had slight play....but he couldn't guarantee it. Low and behold, I had the arms changed (on a whim) and the car 4 wheel tracked. Whilst I'm trying to kid myself in thinking the problem has gone....it remains (albeit SLIGHTLY better). Does anybody have any other suggestions? Thanks. |
08-29-2019, 03:20 PM | #2 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
08-29-2019, 03:27 PM | #3 |
Rep 55
Oh man I had this exact same issue. These are the steps I took:
1) Went to the dealer, explained it felt like steering was binding. They found a fault in the EPS module and reflashed it with new software. Problem was better but not gone. 2) Got an alignment. Followed the recommended loading condition (full tank, weight in driver, passenger, rear center, trunk). Rear toe was pretty far out of spec and evened out the camber. Problem was better still but not fully resolved. 3) Replaced unevenly worn front tires (actually replaced all four but rears were fine) Now the problem seems to be gone. I just got tires today so I'll confirm over the next week. |
08-29-2019, 03:29 PM | #4 |
Rep 80
Michelin....
I forget the model but I'm 99% sure it's either Michelin Green or Michelin Energy, something like that. |
HeresMyCar258.00 |
08-29-2019, 03:47 PM | #5 | |
Rep 80
How badly worn were your front tyres, and why? |
08-29-2019, 04:26 PM | #6 |
Rep 55
Fronts were basically on the wear bars on the outside of the tread. Probably 3/32 or less. Noticeably less worn on the inside. Probably partially because the staggered setup means you can't rotate and partially because the toe was out of spec.
08-30-2019, 02:05 AM | #7 |
Rep 80
Call me thick but what's a staggered setup?
08-30-2019, 02:25 AM | #9 |
Rep 80
08-30-2019, 04:30 AM | #10 |
Rep 609
Drives: F31 330D xDrive MPPK ACS
Rear tyres wider than fronts.
F31 Mineral Grey 330d Xdrive, ACS, Adaptive, MPPK.
Gone but not forgotten: 1967 Triumph GT6 Mk1 (6 pot 2 litre widowmaker) 1966 Triumph TR4A (4 pot 2.2 litre, huge torque, lovely car) 2004 Audi TT 3.2 DSG Quattro (weak springs & nose heavy) 2006 VW Golf GTI (brilliant on good tyres) |
08-30-2019, 10:37 AM | #12 | |
Rep 805
This sounds like a head scratcher, maybe a suspension specialist like centergravity could help? |
08-30-2019, 11:20 AM | #13 |
Rep 55
If the suspension was checked and the only issue were questionable bushings that were replaced I don't see how it could be a suspension problem.
I'd rotate the tires and check if the issue changed at all. I'd do a diagonal rotation (FL <-> RR, FR <-> RL) it might not solve it but if it changes the feeling in a significant fashion then maybe uneven tire wear is contributing. Low rolling resistance tires can be very weird if worn unevenly (cupping, feathering, etc). If there's no change after rotating the tires I'd have the alignment rechecked. Most places will do it for free. Make sure they're following BMWs recommended loading while checking. |
08-30-2019, 02:19 PM | #14 |
Rep 80
No I didn't. I left it with the garage who used a local to align it. I'll swap the wheels around and then do a tracking check.
09-02-2019, 06:36 PM | #15 |
Rep 55
Ok after going on a 200 mile trip this weekend I've confirmed that the issue is not resolved (although it's much better).
Going to go back in this week and have them look again. I believe it's the steering rack. I have noticed it seems to get worse with time. It's more noticeable 1hr in than it is 10min in. It feels "notchy" as I turn the wheel, best way I can describe it. |
09-04-2019, 12:45 PM | #19 |
Rep 55
09-04-2019, 12:58 PM | #20 |
Rep 80
09-05-2019, 08:47 PM | #21 |
Rep 55
Got the car back today, new steering rack installed and re-alignment of the front end.
I think the issue is resolved. Going on another trip this weekend so I'll know for sure but today's driving felt perfect. |
09-06-2019, 01:09 AM | #22 |
Rep 80
