08-21-2019, 04:15 PM | #1 |
Rep 134
Washer fluid low bmw 340i
Hi, is this the genuine washer fluid for a bmw 340i:
https://rover.ebay.com/rover/0/0/0?m...2F254317114859 Anybody know of anywhere cheaper for the genuine one. Got the warning in the car today but want the official one. Many thanks. |
08-22-2019, 12:05 AM | #4 |
Rep 4,935
Drives: 340i MPPSK
Local dealer charged me £18.46 for 5 litres a few months ago.
Life is a state of mind |
08-22-2019, 03:38 AM | #7 |
Rep 570
Dealer charges me £16 ish inc vat generally - more recently I have started to use the tablet version - mix 20 litres of water with the 6 tablets and dump 5 litres of denatured alcohol in it as I can’t get ethanol in its pure form without a licence.
25 litres for £21 In the winter I top it off with more alcohol and works wonders. I get through shed loads, hence the budget version being explored after blowing £80 on screen wash in 6 months 😂 |
08-22-2019, 04:16 AM | #8 | |
Rep 3,068
I used aftermarket screen wash in my last F30 for 80K miles and never a problem, no clogged washer jet or tank and its around £5 litre and will protect down to -20deg. Seems an expensive option to me. |
08-22-2019, 09:20 AM | #9 |
Rep 3,967
08-22-2019, 11:48 AM | #11 |
Rep 1,475
This was my exact reaction to this thread - surely screenwash is screenwash, why pay BMW the premium unless it's a warranty issue (surely not!)?
08-22-2019, 12:04 PM | #12 |
Rep 3,967
Yeah that's probably a strong enough mix, but I get a little paranoid about it freezing up in the cold weather since it did last winter causing the filter to then be blocked. I play it safe with a 50/50 mix now.
08-22-2019, 04:25 PM | #13 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Do a search on it and then you’ll realise how important it is not to mix the screen washes and then it becoming a warranty issue
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
Quantox308.50 |
08-22-2019, 05:22 PM | #14 |
Rep 186
I remember seeing a lot of threads saying that the use of non-genuine BMW screenwash causes the infamous blocked washer jets. One of the members who religiously used BMW screenwash still got the blocked jets. So it's not going to make a huge amount of difference. I personally use the 5l bottle (blue) from Halfords and have never had an issue.
It is very well documented not to use Rain-X screen wash as this interferes with the washer fluid sensor and can damage it. Otherwise I don't think it makes a huge amount of difference. If the jet's are going to block then they'll block regardless of which screenwash brand you use. If I remember correctly someone said it was due to the screenwash bottle forming algae which blocks the filter at the bottom of the bottle. My car is a late 2015 and has never had the issue. My friends early 2015 1 series has the blocked jets and he uses the genuine BMW fluid! |
08-22-2019, 07:01 PM | #15 | |
Rep 3,967
Since having the bottle/filter cleaned out on mine I now only put 2 litres of screen wash in at a time when the low warning comes on. |
08-23-2019, 01:51 AM | #16 |
Rep 314
08-23-2019, 02:18 AM | #17 | |
Rep 3,068
Although saying that the missus doesn't get through much screenwash at all and she has never had an issue in the Z4 |
ukbeemerboy462.00 |
08-23-2019, 03:36 AM | #18 |
Rep 757
You could buy the same screenwash for 10 years and the formula could be changed 5 times a year... how will you ever know its the same?
Just put it in and live the rest of your life haha |
08-23-2019, 03:48 AM | #19 |
Beemer Heaven
462
Rep 2,941
I’ve never had an issue either, but I know people who have as mixing with some products seems to form a gel like substance and blocks everything up. Not cheap to sort out either.
Scott
08-23-2019, 03:56 AM | #20 |
Rep 594
08-23-2019, 03:58 AM | #21 |
Rep 594
I had this exact issue with our X3 (I was able to flush water through the system and clear it all), so went back to the official BMW screen wash.
ukbeemerboy462.00 |
