08-13-2019, 01:47 PM | #1 |
Rep 58
Selecting neutral gear (in automatic) without engine running
Do you really need witchcraft to do this?
Or be related to Evel knievel to perform the mechanical procedure using allen key from under the chassis whilst stuck on a dual carriageway perhaps. I get requiring power to be able to do this i.e. if the battery is flat, you are stuck until you provide power through another car or a battery pack. The fact that the engine needs to be running to select neutral smacks of sheer lunacy. What if the type of fault doesn't allow the engine to be started i.e starter motor or broken belts etc? You can't even push the car out of harms way until a flatbed arrives with 2 dollys? (xdrive) Or am I barking up the wrong tree and there is a simple solution.
Current: F30 335d xDrive, E91 LCI 330d
Previous: Honda Civic 2.2 cdti, E90 330d, E46 330d Saloon, E36 328i Sport Coupe, E36 325iS Coupe, E36 318iS Coupe, Escort xR3i, Renault 5 |
08-13-2019, 02:23 PM | #2 | |
Rep 15,858
Can't even get on a recovery truck without lifting the wheels, or the disengagement procedure under the transmission. |
08-13-2019, 03:19 PM | #3 |
Rep 58
And how many recovery people will know about this and its location.
I have tried some of the methods suggested on forums (from inside the cabin) but to no avail. My previous car had to be towed onto a truck many a time, faults ranging from starter motor, glow plugs, broken belts etc but that was a manual.
08-14-2019, 03:45 AM | #4 |
Rep 424
I wonder if the likes of an XHP gearbox flash would change this? Could be a good marketing point - though if it was anything other than engine powered mechanics required, I can't understand why BMW wouldn't have already used that option instead of this farce.
08-14-2019, 04:11 AM | #5 |
Rep 15,858
Can't see any software changes helping a dead/locked gearbox. (Not anything to do with the transfer box clutches), It's a mechanical action to release the parking lock function, which is the default action with engine off.
08-14-2019, 04:14 AM | #6 |
Rep 15,858
08-14-2019, 06:32 AM | #7 |
Rep 424
Yeah, that was my point - is the action mechanical requiring engine running or is it electrical as the OP suggests. The car can certainly go from Neutral to Park with engine off. It seems a massive oversight that it can't go the other way. Though I'll take your word that it can't, I was just pondering the question
08-14-2019, 10:46 AM | #8 | |
Rep 15,858
My understanding, although actuated electrically, (solenoid, lock magnets, etc.), there's a complex set of safety interactions within EGS (electronic transmission control). Once engaged the lock itself is held in position by spring force. It is released hydraulically. It seems that this is where the limitation may be, and why if the engine is not running it must be cranked to get Neutral, from the shifter procedure. I'm reading that if hydraulic pressure is not available, (the cranking action) then the mechanical release is the only alternative. What I don't understand, is why BMW have decided to remove the link to inside the car, (used to exist in some models) where a 'mechanical' release was possible. |
Stainy265.00 |
08-15-2019, 03:31 AM | #9 |
Rep 1,993
Drives: F30 335d
There is some fascinating info here about the ZF8HP boxes: https://atracom.blob.core.windows.ne...troduction.pdf
About halfway down there is in-depth detail on how the parking pawl works.
if I've helped - an Appreciate would be, er, very appreciated!
