08-12-2019, 11:44 AM | #1 |
Rep 255
Map update help
08-12-2019, 12:32 PM | #2 |
Rep 702
I’m sure that means something like the main map install is 2017-2, but you’re now running 2019-2 after the auto updates for UK maps ( I think EU only updates via usb update and not over the air)
Is your car a 2017 build? Ours is and I’m sure it shows the same info, albeit a different map 👍 |
Pequin230.00 |
08-12-2019, 01:36 PM | #4 |
Rep 8,783
Mine used to download map updates and ask me if I wanted to use them. Always said yes.
It was only in 2019 that I realised I was still running 2016-2. Odd
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
08-12-2019, 01:41 PM | #5 |
Rep 702
I’m not sure HK means you definitely have pro nav, as you still had to spec Pro nav on a Shadow Edition (which if I remember, is what gives you HK, M Sport brakes etc). Have you got widescreen display, or the smaller screen with plastic edges (it’s a bit hard to tell from the photo). Pro nav also has the larger, touch pad iDrive controller
08-13-2019, 05:00 AM | #8 |
Rep 470
08-13-2019, 06:37 AM | #9 |
Rep 32,881
OTA only updates the UK map, which you have the latest version. If you want to update the full Europe map you need to do USB update from the connected drive website.
08-13-2019, 01:39 PM | #11 | |
Rep 255
What's the file size and I guess I'm plugging it into the centre console USB. I think I have a spare 16 or 32gb somewhere. I've since had a look at the vin build sheet and it confirms: S606A - Navigation system Business It's no biggie as the navigation is adequate for what I need and the voice search is great if I tone down the Geordie accent. Just surprised more than owt else. |
08-13-2019, 01:41 PM | #12 | ||
Rep 631
335D EB LCI - Debadged
