08-11-2019, 02:12 PM | #1 |
Rep 1,509
F32 LCI coding help for USA member
Greetings from the USA. I'm hoping a UK member will help me out by checking a couple of values on a UK LCI F32.
REM -> 3063 -> Mapping_Nebelschlussl_L_output (Value = 00x20) REM -> 3063 -> Mapping_Nebelschlussl_R_output (Value = 00x21) Our cars come with rear fog lights disabled. It's pretty easy to modify the switch to work, but the rear lights need to be coded. So far, the only solution I've found uses the upper, outer turn signals, not the inner light segments on the trunk (boot?) lid. I suspect the hex values correspond to a segment of the light unit. Your help would be greatly appreciated. |
