08-13-2008, 01:05 AM | #1 |
G.O.A.T.!
1000
Rep 74,998
SupremePower / Alcon Brake Special!!!!
SupremePower is proud to offer Alcon Brakes!!! For E46M3!!! MSRP on the BBK is $3695.00 for the front - 14.4” (365mm) mono 6piston MSRP on the rear kit is $2595.00 - 13” (332mm) mono 4piston SP special price... Front only $3195 (save $500!) Rear only $2295 (save $300!) Front and rear $5195 (save $1095!) Call to order at 714 632-1951 Advantage Extreme Stopping when you want to - and more importantly when and where you need to - is a fundamental requirement of attaining speed. Alcon’s advantage extreme brake kits have been designed to do just that. Providing ultimate braking performance in a direct replacement package, these kits make use of the technology behind Alcon’s involvement in top level motorsport, including F1, World Rally Championship, NASCAR and Japanese GT racing. What’s in the box? The advantage extreme kit is a complete left or right hand brake package and includes all the parts you will need, including: Special alloy disc and bell assembly Monobloc 4 or 6 piston caliper Low noise, fade resistant pads Brackets and fixings Braided hose and fixings High performance brake fluid Please check that your wheels are compatible with the advantage extreme brake kit by obtaining a radial profile template from your dealer. Calipers Advantage extreme calipers are gravity die cast monobloc constructions using aluminium alloy for optimum strength and weight. Other caliper benefits: Monobloc 4 or 6 piston design for high stiffness (firm pedal) with low weight Piston bore sizes are staggered to ensure even pad wear Pin-mounted pads provide low threshold pressure and low noise Pads These low noise pads offer strong cold performance for start up and city driving and are specially formulated for excellent resistance to fade at elevated temperatures Discs Advantage Extreme discs have been engineered to produce optimum bite, thermal stability and durability in an exceptionally high strength to low weight design. This has been achieved by combining a special Alcon developed iron alloy disc with an aerospace specification alloy bell. Other disc benefits: Unique crescent grooves on friction faces provide the bite usually associated with drilled discs without the attendant durability problems Directional curved cooling vanes for optimum cooling performance Alcon’s floating disc system (as used in the majority of applications) has been designed to allow thermal expansion of the disc throughout its life while minimising the tendency to judder No additional parts are required to fit an advantage extreme kit to your car - all brackets, fixings, braided hoses and high performance brake fluid are included. Fits under the 18” STOCK E46 M3 Wheel! And fits under CSL Reps |
08-13-2008, 05:21 PM | #2 |
Rep 473
Hey can yo post up a photo of the volk re30 limited edition???? In the blue..I wonder how it would look on a jeraz black m3??? Waiting on your pm...For pricing...
08-14-2008, 10:38 AM | #4 |
G.O.A.T.!
1000
Rep 74,998
