E93 unanswered questions for the gurus.
07-08-2019, 05:47 PM | #1 |
Rep 66
2007-07-14 BMW 328i
hey guys new here and have a few questions while I think this has been talked about over and over again, I still think there are some questions missing. i just picked up the car not long ago. i have done all the reading and 1, have the MULF2 in the trunk mat marked with bluetooth symbol 2, have the aluminum box in the left side of the trunk liner 3, have USB/AUX in console 4, have buttons on radio and steering 5, I do have the talking face button on the steering wheel just above the phone button, doesn't do anything either. 6, ran VIN = S640A Preparation F Tel Installation Universal? I don't have SOS on the roof as its a convertible, I have not seen it. i don't have a phone option in the ratio menu. however in the menu it asks me the telephone volume level but I don't seem to have the phone option/ does this mean I have the mic and all other accessories and there is something wrong or what? I'm not looking for a of topic answer ive been a bmw guy for a while and know what I'm working with. i have done a lot of reading and lurking so I'm familiar. thanks guys, glad to be back in a bimmer. Last edited by kissdaring; 07-11-2019 at 10:33 AM.. Reason: MULF2 not TCU in #1 |
07-09-2019, 05:38 AM | #2 |
Rep 2,758
can you make photos of the modules in trunk ?
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
07-09-2019, 12:10 PM | #4 |
Rep 66
07-09-2019, 03:23 PM | #5 |
Rep 2,758
you have MULF2HIGH module, not TCU, so you do not have SOS button
but since you have 640 option that mean that you probably have mic in steering wheel trim it is quite easy to remove steering wheel trim using plastic trim tool to check that you may also unscrew mulf2high module bracket and make more detailed photo of the wires coming to both sides of the module
07-09-2019, 03:35 PM | #6 |
Rep 66
Sorry PT is what I meant MULF. I will take photos of the wiring and report back. Just a quick question. Is there a phone/Bluetooth fuse or anything like that that I can look into? Considering I don't have the option in the setreo menu might it be a fuse issue you think? Thanks.
07-10-2019, 11:49 AM | #8 |
Rep 443
Drives: '11 E93 M3 6MT, '08 E92 335Xi
and you can't pair your phone using the radio BT setup? I have a coupe, but this video worked for me:
Pete
07-10-2019, 01:53 PM | #9 |
Rep 66
No offense but anyone else with a bit more experience if this car has bt or not? Considering there is a mulf2 and it's connected I don't see why there would not be any bt? Thanks guys
07-10-2019, 02:38 PM | #10 |
Rep 1,965
How's the basement renovation going Jaye?
First off, I would start the car and set my phone to discoverable in the bluetooth options; see if it recognizes the car. Second I would go into the options outlined in the video someone posted above to see if you have the option to pair with a phone from the car. Third I would go here (https://decoder.bvzine.com/), enter the VIN number and see what options your car has. A really quick Google search should give you everything you need to know. |
07-11-2019, 10:32 AM | #11 | |
Rep 66
thanks gus |
07-11-2019, 10:52 AM | #12 |
Rep 2,202
Yes BMW did include all those buttons on steering wheel and radio even for cars that did not have those features. The mulf2 is there for USB only. If there is a mic present, we would not know; you'd need to physically check that as ptpending mentioned few posts up.
Since you already have prep option for telephone then that means the wiring for mic are present. Add a mic, Code the mulf for telephone then reset RAD to VO and you should have telephone working.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
07-11-2019, 11:22 AM | #13 |
Rep 13,116
To find your actual installed options use a free BMW
online Vin checker. https://www.google.com/url?sa=t&rct=...pytm6ui2dWc1zK Options with prep means wiring is installed module may or not be installed and not enabled. |
07-11-2019, 11:28 AM | #14 |
Rep 66
thanks guys.... i will take a look at the wheel shortly to see if i have the mic in there. anything else I should be looking at? bluetooth antenna or anything? I checked the fuses too and all are ok. these are the options I'm getting for multimedia over at VIN CHECK,
Multimedia S640A Preparation F Tel installation Universal S677A HiFi System Professional DSP S694A Provisions For BMW 6 CD Changer S6FLA USBAudio Interface S645A BMW US Radio S663A Radio BMW Professional thanks again guys for giving me a hand in figuring this out... |
07-11-2019, 12:09 PM | #15 |
Rep 443
Pete
07-11-2019, 01:15 PM | #16 |
Rep 66
So I just took a peak under the steering cover and there is no mic installed. There are however 2, 2 pin plugs there. I'm guessing for the mic install. Photos will follow in a sec. Also I took a look under the left back lining will post photos of this too.
07-11-2019, 01:21 PM | #17 |
Rep 66
07-11-2019, 02:24 PM | #18 | |
Rep 2,758
you need to get mic for the cabrio and bluetooth antenna, install them and code bluetooth handfree option in headunit and bluetooth modules
07-11-2019, 04:36 PM | #19 |
Rep 66
07-11-2019, 05:03 PM | #20 | |
Rep 66
thanks Last edited by kissdaring; 07-11-2019 at 05:10 PM.. |
07-11-2019, 05:11 PM | #21 | |
Rep 66
07-12-2019, 03:11 AM | #22 | |
Rep 2,758
it's located in drivers footwell on the internal side of the footwell trim keep in mind that cabrio mic part number is not same as in sedan, coupe or touring
Tags |
bluetooth, phone, tcu bluetooth, telephone |
