E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > "A" Column cover removal
      08-11-2008, 10:35 AM   #1
tmarshall57
tmarshall57's Avatar
Drives: F10 530d M Sport, E87 118d M
Hi
DO any of you know how to remove what I believe is called the "A" column trim cover i.e. the trim covering the right and left windscreen pillars with the "Airbag" badge on. I want to conceal some wiring behind the trim (the aerial wire from the Pure Highway DAB unit).
Thanks
Tony
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
      08-11-2008, 12:35 PM   #2
R4R
R4R's Avatar
Drives: E89 Z4 35i
Originally Posted by tmarshall57 View Post
Hi
Thanks
Tony
Tony, most in car equipment fitters remove the door rubber and then slide the wire in behind there. they dont always remove the A pillar trim.
35i - DCT - Most of the toys - Smart top roof module - GLF.
www.onboardvision.co.uk
www.gtvr.co.uk
www.vehicle-launch-incar-video.co.uk
      08-11-2008, 04:38 PM   #3
tmarshall57
Thanks. I PMd a guy in the US who had replaced his headlining and all related interior trim with anthracite trim.
The answer is to remove the "airbag" badge and then remove the torx screw underneath. Apparently the trim then just pulls off.
      08-12-2008, 09:28 AM   #4
RichardM
England
133
Drives: G21 M340i LCI
Be careful fitting them again as its very easy to break the plastic clips. It does all come off quite easily. Have a look at the threads in the DIY section.
2023 G21 M340i LCI
Previous - 2020 G21 330d M-Sport, F31 335d M-Sport, F31 330d M-Sport
      08-13-2008, 05:05 PM   #5
tmarshall57
OK - will bear in mind - thanks
Tony
      09-17-2009, 06:13 AM   #6
atlau
Germany
Drives: 328i E92
Do you just pry off the "Airbag" badge?
Thanks!
      09-17-2009, 06:49 AM   #7
M3-FAST
Defected to the dark side.....
M3-FAST's Avatar
England
210
Drives: BMW M5 LCi
+1 - thats exactly what I did on my E93 when fitting the car phone kit - a lot easier than trying to remove the trim and can't cause any damage!
      09-17-2009, 04:52 PM   #8
RichardM
England
133
Thanks!
Yes. Its easy to do and easy to remove and refit the trim.
2023 G21 M340i LCI
      09-17-2009, 05:15 PM   #9
Dr Dave
Zummerzet Zyder Drinker!
Drives: '06 330D Le Mans Blue
Slip the door seal rubber out of that way, install cabling and refit, that's the way to do it.
      09-18-2009, 02:00 AM   #10
atlau
Germany
Drives: 328i E92
Thanks Richard. I was just worried I'd somehow fire off the airbag and knock myself out
      09-18-2009, 12:59 PM   #11
atlau
Germany
Drives: 328i E92
Richard.. any tips on putting the A pillar trim back in place? The reason i took it apart is the garage had put it back on all jacked up.. in fact the plastic edges that stick out werent in the appropriate grooves... I guess tomorrow I'll fiddle with it to try and stick it back in there... its kind of a pain in the b#tt!
e90post
