best launch technique 335i stick
08-10-2008, 01:09 PM | #1 |
Rep 1,654
Drives: AW M3
dtc off or full dsc off?
rev to what? |
08-10-2008, 01:19 PM | #3 |
Rep 7,789
put the car in manual, turn DTC off and rev up to MAX of 4000 RMP , 4000 its still too much and it might give you a lot of tire spin, so i recommend around 2000 rpm and then floor it on the GREEN !!!!! good luck
08-10-2008, 01:22 PM | #4 |
Rep 7,789
my bro usually turns DTC off and not DSC, 2500 RPM is pretty reasonable rev and it should give you no tire spin and pretty reasonable launch !!
08-10-2008, 01:27 PM | #5 |
SUPERMAN
121
Rep 3,171
ill try it with dtc on only but when i usually have dtc on the car tends to bitch out lol...and i think for you its a lot easier since u have at right? i have mt
08-10-2008, 01:37 PM | #6 |
Rep 1,654
Drives: AW M3
re
what im doing is DTC off (dsc still on) reving to about 3... slowly let the clutch go, let it catch, then pedal to the floor... sound about right
08-10-2008, 01:53 PM | #7 |
SUPERMAN
121
Rep 3,171
08-10-2008, 02:25 PM | #8 |
Rep 1,654
Drives: AW M3
dsc fully off gives me CRAZY tire spin it consumes the entire first gear... to fight that i gotta let off the clutch so slowly it kills too much time... i find its easier with just DTC off... unless im doing something wrong
08-10-2008, 02:38 PM | #10 |
Rep 1,654
Drives: AW M3
it sounds stupid but EVERY video i see on youtube of 335s going 0-60 in 4.0-4.1 etc has the DTC light on so thats probably how im gonna keep it.... also.... do you all bring it to redline before you shift? max hp is said to be 5800rpm so why bring it to 7
08-10-2008, 02:42 PM | #11 |
SUPERMAN
121
Rep 3,171
ooo ok so i guess your right..i just assumed that with traction completely off that it would give u the best hook but i assumed wrong..i have to try lunching the car with dtc only
08-10-2008, 03:13 PM | #12 |
Rep 10,509
whoa. don't do that. You are wearing out the clutch big time with WOT launch and big clutch slip
08-10-2008, 03:17 PM | #13 |
SUPERMAN
121
Rep 3,171
08-11-2008, 01:22 AM | #14 |
Rep 1,654
Drives: AW M3
i mean is there any way to launch without wearing out the clutch realistically... either dump it out get loads of spin or slowly let up until it catches and then pedal down... either way seems damaging to me
08-11-2008, 01:58 AM | #15 | |
Rep 1,657
if so, the next thing to understand is that based on the gear ratios, when you shift from 1-2 it drops you in a diffirent rpm in 2nd gear than say when you shift from 2-3 (ex: say you shift at 6,000 rpm in 1st you end up at, just for sake of argument, at 4,500 rpm in 2nd; but if you shift at 6,000 rpm in 2nd you don't necessarily end up at the same 4,500 rpm in 3rd). So shift points are diffirent from gear to gear. i have hear that in 1st and 2nd its optimal to redline and in 3rd its optima to shift around 6700 and in 4th aroun 6400. I've looked at the graphs and that makes sense. shifting any sooner than that drops you in lower hp than you would get than if you stayed in the lower gear (even though both numbers are less than peak). the other way of looking at it is through torque multiplication to see what force is applied to the ground and maximizing that force. but no matter which way you go, engin hp or gear mulplied torque, you find the optimal shift points are the same.
"KOPEYKA" /// Titanium Silver / Black Leather / Gray Poplar / Sport Package / Premium Package / 6MT / Feb 08 Production |
08-11-2008, 02:04 AM | #16 |
Rep 458
Drives: AW/FR '11 e92 M3 ZCP
well i have a steptronic and i get better launches when i do it with the dtc light on....(the one where u just press it once) it seems to work better for me than it completely off because when i launch with complete off theres alot of wheelspin
[SIGPIC][/SIGPIC]
335i-SL55-M3!!!!!!!! |
08-11-2008, 02:44 AM | #17 |
Rep 10,509
08-11-2008, 09:59 PM | #18 |
Rep 1,654
Drives: AW M3
so general consensus is rev to between 2500-2800 with only DTC disabled (dsc still acting) and slip the clutch?
also +1 to mrmojo very informative post on when to shift... |
09-14-2008, 01:41 PM | #19 |
Rep 171
is it true that the more engine mods you have the lower you launch point gets?
for example i have catless dp's exhaust and JB3.. i feel as if 2500 is way to much |
09-15-2008, 01:08 AM | #20 | |
Bootleggin' 'n Gunrunnin'
137
Rep 2,372
DSC - Dynamic Stability Control. Default is ON. This is the most aggressive setting for the computer to step in and take over. DTC - Dynamic Traction Control. Default is OFF, because DSC is ON. Pressing the "DTC" button once briefly turns on DTC. This setting partially disables some of the DSC intervention and will allow a little more wheel slip before stepping in and taking control. When you see "DTC" on the dash, that means that DTC is ON, and DSC is reduced. So DTC is like a more forgiving DSC. OFF (Triangle with exclamation and arrow-circle) - All systems are OFF. DSC is OFF, DTC is OFF. You will notice that most posts in the General E9X forum about crashes will reveal that DSC and DTC were both OFF Anyway, try launching under each setting with the same conditions. Something like: DSC ON: Rev to 2500 and go. Notice lack of wheel spin and/or heavy intrusion of DSC. DTC ON (one button push): Rev to 2500 and go. Notice some wheel spin, but also that the system will jump in at some point. DSC/DTC OFF (cool triangle symbol, long button push/hold): Rev to 2500 and go. Notice how you are bouncing off the rev limiter and going about 20 MPH because one of your rear tires is going up in smoke.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
09-16-2008, 01:13 PM | #22 |
Drives Smart
54
Rep 2,393
The good thing about the N/A cars is we can launch with it all
the way off!! My car is really slow though so doesnt matter all that much No torque= win lol jk jk
08 BMW ///M5 Space Gray/Black 6 speed Engine: RPi GTS exhaust, RPi Scoops, Carbon Filter Delete Exterior: Glossy Black Kidneys, LUX V3, OEM LED License Plate light, Bruce License Plate Adapter |
