BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    IND | BMW M Performance Coilover Kit
      06-03-2019, 02:05 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9586
Drives: G82 M4 / G87 M2
Finally released! Have a set here at IND and took some photos.
The M Performance sleeve kit for the F90 M5 allows a large range of height adjustment while retaining the factory electronic damping control. The factory spring perches are removed from the front dampers, and BMWs own threaded height-adjustable perches are installed. The kit includes height adjustable spring perches for the front and rear, strengthened and shortened bump stops and shock sleeves to protect the OE BMW dampers.The BMW M Performance H.A.S. kit is EDC compatible!
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      06-03-2019, 05:51 PM   #2
dardeca
dardeca's Avatar
Drives: 2019 M5 Competition
How does the drop compare to something like the H&R F90 Sport springs?
Also, any sense for it the spring rate on these is supposed to align with the base M5 springs or if they are stiffer and similar to the M5 Comp springs?
E92 M3 Supplemental manual p.38: "The laws of physics cannot be repealed, even with DSC."
      06-03-2019, 07:04 PM   #3
TrevorM3
Drives: 6.3 AMG
of course this shit comes out as soon as car arrives in port..
      06-03-2019, 07:31 PM   #4
dardeca
dardeca's Avatar
Man...all you do is complain about missing out on the 2020 updates, add'l product releases, etc. There will ALWAYS be change...if you always want to have the latest and greatest options, then you might as well never buy/lease anything...you'll always lose as something new will always come out.
With that said, I suspect this is a aftermarket only option...I wouldn't expect this to be a port installed option.
You ordered an amazing car...just enjoy it.
      06-03-2019, 07:41 PM   #5
apsuard
Drives: 2021 BMW M5 Competition
Does this kit lower more than KW? I know a few have not liked the max drop on KW especially in the front. Hopefully this allows for a larger range of adjustability
      06-04-2019, 04:13 PM   #6
MpowerMike
MpowerMike's Avatar
360
Drives: 2012 IB BMW M5
+1! IND can you guys please confirm if these go lower then the kw’s . I’m not happy with the drop especially the front on my Kw’s
wieisme110.00
      06-04-2019, 05:02 PM   #7
Bart@AUTOcouture
Bart@AUTOcouture's Avatar
1006
Drives: F95X5M | E46M3 | E92M3 | E60M5
Subscribed for comparison pics to KW HAS!
dardeca499.50
      06-04-2019, 05:18 PM   #8
TrevorM3
Drives: 6.3 AMG
calm down, i made one comment missing out on laser lights.
This spring set is available via BMW, it was on their catalog for the f90. It was suppose to be released a month ago.
      06-04-2019, 05:37 PM   #9
hybrid_eg
hybrid_eg's Avatar
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
i don't see why this would go lower than KW HAS, factory shocks are valved for specific amount of travel.. adapting any HAS kit can only reduce that and especially ride quality if you bottom out the kit, but I'm curious to see the comparison nonetheless.
      06-05-2019, 01:02 PM   #10
andrewsd
andrewsd's Avatar
Drives: 2021 M3c
I'm curious on a review of these as well, also how they affect ride quality.
Anyone get it installed yet? My dealer is saying around 3k all in.
      06-05-2019, 02:20 PM   #11
hybrid_eg
hybrid_eg's Avatar
For 3K you might as well buy actual coilovers.. pricing should be no different than whats available for F8X chassis, if its more than its the result of M5 tax, lol
      06-06-2019, 08:13 PM   #12
dardeca
dardeca's Avatar
MSRP is $1860 for the parts...so install another $1100 or so...that sounds about right.
      06-06-2019, 09:04 PM   #13
TrevorM3
Drives: 6.3 AMG
part #?
      06-06-2019, 09:25 PM   #14
dardeca
dardeca's Avatar
part #?
Genuine BMW Retrofit Kit Sports Suspension 319010 - Part Number 33-50-2-456-208
      06-07-2019, 07:23 AM   #15
TrevorM3
Drives: 6.3 AMG
thanks! may end up sticking with H&R i guess, even with my discount it's not enough to justify the price on these.
      06-07-2019, 09:27 AM   #16
dardeca
dardeca's Avatar
I have H&R F90 Sport springs on my M5 Comp now...overall really happy with them. However, I would be interested in seeing how these M performance springs look once installed.
      06-07-2019, 02:28 PM   #17
hybrid_eg
hybrid_eg's Avatar
So about couple hundred more than KW, not bad for OEM part. (I saw getbmwparts.com) already has it listed for $1517, $1100 is pretty overpriced for install unless it includes corner weight + alignment.
      06-07-2019, 05:55 PM   #18
dardeca
dardeca's Avatar
Well, after seeing the effort involved in installing the H&R Springs on my M5 Comp...I'd say it's a lot more labor intensive than one would expect. To get to the rear struts, you have to take apart a good portion of the rear interior...which is not all that hard...but is time consuming.
      06-08-2019, 07:46 PM   #19
TrevorM3
Drives: 6.3 AMG
yea we're doing H&R, but the 550i springs, i saw your car. looks sweet! much improved over stock.
dardeca499.50
      06-09-2019, 09:19 AM   #20
dappercivility
dappercivility's Avatar
204
Drives: F90 M5 Competition
Has anyone installed the M Performance HAS kit yet? I'm not a fan of how the KW HAS kit that has the front having wider gaps compared to the rear.
Born in M Town
      06-09-2019, 10:43 AM   #21
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
The KW Kit is very good if you're looking for OEM ride quality and adjustability with little bounce or rebound.
The front height comes into play if you're looking for a more aggressive drop. If you're looking for a moderate drop it is simple to get all four corners to have the same tire / fender gap.
If you go aggressive (bottomed out or close to it) on the rears you can't match the fronts as they simply don't go as low as the rears. The flip side is this aggressiveness will come with more rebound and bounce.
It will be interesting to see the M-Performance Kit and how it looks, and more importantly, feels.
I've had KW HAS on two F10 M5's as well as my F90 M5C and have been pleased overall.
In the end, how low you want to go will play a huge factor in the suspension you choose.
The M550i H&R springs look really good if you want a drop that's more aggressive.
KW HAS or H&R M5 springs both work well for a less aggressive drop with the KW having the benefit of adjustability.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
FSHNGRY2336.50
      06-09-2019, 12:41 PM   #22
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
I'm wondering why the BMW suspension engineers decided to approach their HAS differently than KW? KW uses the helper spring to keep tension on the main spring if you choose to use the maximum drop of adjustment. Does the BMW method give a smoother ride with more large diameter spring to use for all of the travel? But, which has the more firm ride?
I wish either BMW or KW would give their customers more information on the spring rates. All I've heard from the KW distributor is that they're progressive, so we can't give you a rate. Perhaps that's true, but they could easily put them on a test rig, start pressure readings at installed height, and then give a pound reading every 1/4" of travel until coil bind, or whatever the suspension travel is. That way we'd have a way to compare the kits.
I've asked IND if they might do that, or have Fall Line do that, but doubt either will do it. Not much incentive for them to take the trouble. I'm considering spending the extra money for the BMW HAS just to see. I had the KW v3 on my F10 and thought it was very good, but I'm not going to spend the money for their v4 for the F90.
m5post
