05-14-2019, 08:19 AM | #1 |
Rep 179
Running spacers with larger MP4S?
I need to replace my tires and I am running Supreme Power spacers 15f/12r. Are 285/305 possible without rubbing? I am lowered on KW HAS kit.
05-14-2019, 04:13 PM | #2 |
Rep 5,233
You should be fine.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
05-14-2019, 10:22 PM | #3 |
Rep 427
Drives: 2019 M5 Competition
Can you run 285/305s without messing up the AWD due to rolling diameter deltas?
05-16-2019, 09:50 AM | #4 |
514
Rep 1,437
I replaced my Pirellis with the Michelins and I run a 285 front and 295 rear. Michelin doesnt make a 305 rear in the PS4S. I run 13mm spacers on all 4 corners. No rubbing at all. Stock Comp suspension. Rear is close. You may rub if lowered on KW's. You may not be able to go beyond a 10mm spacer. Unfortunately, you have to test fit and see for yourself. If you run a 285 rear, you may be fine. I just wanted as wide a tire as I could get.
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
05-16-2019, 02:31 PM | #5 |
Rep 5,233
Yes
05-20-2019, 12:21 PM | #6 | |
Rep 1,051
