F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding a locked AC compressor
ARMA SPEED
      05-10-2019, 10:28 AM   #1
AlbertoSONIC
Drives: 318d F30 LCI
Hi everyone, some time ago I've been involved in a crash in which I broke the AC radiator. The mechanic replaced it and filled AC gas but now the AC isn't working anymore. He told me that the AC compressor has activated a sort of protection and locked up, so he told me I need to go to a bmw dealer to unlock it. Is this possible? I tried to read error codes using Bimmerlink but I'm not getting anything. Given that I have the obd-ethernet cable, is there something I can do with e-sys or other bmw software to fix it on my own?
      05-10-2019, 11:33 AM   #2
atzebmw
Germany
588
Drives: Tesla Model 3
I just searched in ISTA/Rheingold for some hints for a compressor protection lock, but i found nothing.
You can try to read the error memory with ISTA/Rheingold and there should be some errors for the compressor and solution tips.
Here you can ask for ISTA/Rheingold:
https://f30.bimmerpost.com/forums/sh...highlight=ISTA
      05-11-2019, 01:45 PM   #3
AlbertoSONIC
While waiting for the enet cable to arrive, I've tried to read error memory with Bimmerlink. I don't see anything related to it... what do you think? Which ecu should be responsible of this issue?
ZGW
2 errors
CD0487: SYNCHRONIZATION FAILED, CC WAS NOT SYNCHRONIZED WHEN DEBUG LOCK WAS RELEASED
801C20: CENTRAL FAULT MEMORY FULL
MOTOR
2 errors
283400: LAMBDA PROBE TO KAT, HEATING CONTROL: INTERRUPTION
282E00: LAMBDA PROBE TO KAT, HEATING CONTROL: SHORT CIRCUIT TO POSITIVE
ICMQL
1 error
480134: SBS FUNCTION - DIRECTION OF TRAVEL UNCERTAIN AT VX GREATER THAN 2 M/S
KOMBI
1 error
B7F668: COMBI: SYSTEM TIME HAS BEEN RESET
MMI
4 errors
B7F850: CONNECTION HEAD UNIT TO THE MICROPHONE 2: LINE INTERRUPTION
B7F8C3: CID DOES NOT RESPOND (HARDWARE FAILURE: FAILURE OF CID COMMUNICATION)
B7F8CB: IMAGE DATA INVALID OR INCORRECT E1C447: MOST: A CONTROL UNIT HAS LOGGED OFF
FRM
4 errors
030195: FH BFH: INVALID CHARACTERISTIC, NO STANDARDIZATION AVAILABLE 030196: FH BFH: MOTOR TEMPERATURE EXCEEDED 90 PERCENT THRESHOLD 030197: FH BFH: MOTOR RUNNING INTERRUPTED DUE TO OVERTEMPERATURE 0301A0: FH BFH: SYSTEM IS NOT NORMALIZED
And in info memory (only klima related.. am I looking for the wrong thing?)
KLIMA
3 errors
078022: MESSAGE (VEHICLE CONDITION, 0X3A0) IS MISSING 07802B: COMM_E_NET_START_IND_CHANNEL_0
078043: LINIF_E_RESPONSE
      05-12-2019, 03:49 AM   #4
atzebmw
Germany
588
That's a lot of error messages.
But that's the only message related to your problem i think.
Originally Posted by AlbertoSONIC View Post
KLIMA
3 errors
Actually the ecu is called IHKA or IHKA2.
Did you try to delete the error memory?
      05-12-2019, 06:01 AM   #5
AlbertoSONIC
KLIMA
3 errors
I tried to clear error memory this morning, then turned on engine and ac and... it didn't work. And not a single error came up. Is it possible that it's not signaling anything?
The compressor clearly isn't engaging, the rpm keeps stable when I press the AC button..
      08-16-2020, 04:58 AM   #6
hatak
Drives: BMW4 GC
ZGW
2 errors
MOTOR
2 errors
ICMQL
1 error
KOMBI
1 error
MMI
4 errors
FRM
4 errors
KLIMA
3 errors
Hi I have 430i f36 after program modification, I've noticed that you have same 2 errors as me
I'm wondering if your car is also chip tuned?
Regards
Maciej
f30post
