F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [SOLVED] Fog turn signal and lights height adjustment button
Studio RSR
      05-09-2019, 09:28 AM   #1
xvx45
Drives: f31
Hello,
Since I've coded my f31 to get fog light in turn, the lights height adjustment button is not working anymore.
I've halogen headlights, since the modification, headlight make vertcal move when I sart the vehicle but the height is only OK when there is no mass in the trunk but not with mass in trunck : I spot the sky.
Does anyone have a solution to enable fog turn signal AND lights height adjustment button ?
If I disable turn fog signal, does the height button will work again ?
Sorry for my poor english and thank you for your answers !
Regards,
EDIT : Solution by cjn
- change back "FEM_BODY" : "3073" : "C_BLC_ENA" to f30disable
      05-09-2019, 10:04 AM   #2
cjn
Drives: 2021 F40 M135iX
Thumbs up
Originally Posted by xvx45 View Post
Hello,
Regards,
If you followed the usual recommendations you probably did these:
FEM_BODY
3062 MAPPING_ABBIEGEL_L/R_OUTPUT = nsw_l / nsw_r
3062 MAPPING_ABBIEGEL_L/R_PWM_LEVEL_1 werte = 64 (100%)
3066 KL_ENABLE_LI/RE = KL_Ein
3073 C_CLC_ENA = enable
3073 C_BLC_ENA = enable
The last one was the killer on my car. I think it's only relevant for adaptive headlights. Leave it disabled and see if your height control works.
      05-09-2019, 10:45 AM   #3
xvx45
Drives: f31
Hope Bimmercode used to changes those values. I'll take a look in advanced mode and will change 3073 C_BLC_ENA to disable (maybe tomorrow). Finger crossed, I hope that that's the same as your car ! I'll tell you here if it is fine.
And thank you of course
      05-09-2019, 11:13 AM   #4
cjn
Good luck! I would definitely use enhanced mode so you can see exactly what's being changed.
      05-10-2019, 04:43 AM   #5
xvx45
Drives: f31
Smile
Thank you cjn, it worked, I'm now able to manage headlight height without loosing fog light in turn !
      05-10-2019, 06:35 AM   #6
cjn
      05-22-2023, 06:43 AM   #7
SFpaulo85
Drives: F31
Hello guys, decided to bring this post to live instead of creating a new one
I have coded fog turn lights as describled above and it works good, however I noted that the light is very weak and It makes no difference having it or not, when I just turn on fog lights then is much stronger.
Is there a way to make the cornering light stronger as the normal fog lights?
      05-22-2023, 11:02 AM   #8
TheNine90
Drives: bmw
Try changing the PWM_LEVEL
      09-28-2023, 02:17 PM   #9
Hangnail-Lyricist
Drives: F30 2014
FEM_BODY
Thanks man, I've failed MOT and been looking for the solution for over a week. Coded and it's working now!
      11-06-2023, 03:57 PM   #10
c_kick
Drives: 2013 F31 318D
Just registered (long overdue anyway) to say this was a lifesaver! Height adjustment didn’t work, though the beams clearly dipped and rose each time at startup, and it was driving me mad. Setting BLC_ENA to disabled was indeed the fix. Thank you!
f30post
