Went Autocrossing and have questions
08-03-2008, 07:57 PM | #1 |
Rep 184
I went Autocrossing with the local Corvette club in my stock 335i coupe. My tires were set to 38psi cold all around. After the first few laps (yes, we had 10 laps), I noticed that my car started sliding around coming out of the turns, and I was also fighting the car during the turns (front tires look worst than the rears). After all the laps were over, one member suggested that I lower the tire pressure after the first few laps, because it was probably in the lower 40s. I didn't actually have a guage with me to check it.
I'm going back in 2 weeks, and would like to find out what was causing this problem. Maybe I was going too fast into the turn...I dunno. Thank you.
2007 335i Coupe
Black Sapphire Metallic | Coral Red | Gray Poplar Wood Trim | Sports Package | Premium Package |
08-03-2008, 08:04 PM | #2 | |
Rep 1,288
Drives: 135i
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
08-03-2008, 10:49 PM | #3 |
Rep 10,509
Yes, I agree the tire pressure could be too high. I'd start off with 32psi cold. Most people increase the tire pressure to try and prevent sidewall roll over, and if you have run flat tires, r compound tires, or a street tire with mega stiff sidewall (RE01R, RT615, etc) you don't need high air pressures. (Also, in all tires, high pressure decreases available grip because the contact patch is decreased.)
Also, you could be trying to go too fast in the slow sections. You should ask an experienced person to ride with you and give you pointers. Best of luck! |
