04-16-2019, 02:54 PM | #1 |
Rep 702
TPM question
I just got my base M5 April 5th. I have a question about the Tire pressure monitor.
It keeps warning me that tire pressure is low even though all tires are at or above 32-33psi which is the recommended pressure on the door frame sticker and as listed in the owners manual. I have it set for the correct size rear 20 inch summer tires for travel <100mph. The iDrive displays recommends the pressure be 42 psi or higher! Why? I can't seem to reset this. Any thoughts? See pictures.
2023 M3: Isle of Man Green
2021 X7 40i: Phytonic Blue |
04-16-2019, 03:26 PM | #2 |
Rep 100
I had the same problem. Tried changing different settings but the light kept coming up. When I dropped a car off for 1000 mile service, they fixed it.
04-16-2019, 04:06 PM | #4 |
Rep 862
Dealership set my tire pressure to 42psi to resolve...
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
04-16-2019, 07:55 PM | #5 |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
32-30 is the normal pressure that they warn you they are low. Pressure should be higher.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
04-16-2019, 08:06 PM | #6 |
Rep 1,313
+1
E92 M3 Supplemental manual p.38: "The laws of physics cannot be repealed, even with DSC."
04-16-2019, 09:20 PM | #7 | |
Rep 4,109
At 60F ambient (90F+ in the tire), it's suggesting 38psi front and 39psi rear. Important note that just occurred to me: I have custom tires on standard Comp wheels and configured the car as such--I'm running Michelin Pilot SuperSports 295/30/20 rears and 285/35/20. |
04-16-2019, 10:46 PM | #8 |
Rep 702
Yes, these are the cold tire pressures on my iDrive (32-33psi). Sounds like the consensus is the cold pressure in the tires should be set to the recommend iDrive pressures - I guess around 42 psi even though that seems pretty high to me (and higher than the door frame sticker and owners manual suggest).
04-16-2019, 11:52 PM | #10 |
Rep 114
After you adjust the tire pressures, confirm the tire settings and you'll want to allow the TPM to reset itself before the notification disappears.
04-17-2019, 02:45 AM | #11 | |
Rep 1,319
This should be correct then. If you set them cold, then the heat and pressures should rise accordingly, and the TPM should be fine. Ive set my pressures to the quoted numbers on the door sticker, and they have been fine, no problems. |
05-02-2019, 07:17 PM | #12 |
Rep 217
Came here for the same thing. Switched from my winters to my summers and the warning light won't go out. Keeps asking for 45psi. Door sticker and tires say 32.
BMW newbie, please be kind and patient
2019 M5 Competition. |
05-02-2019, 07:22 PM | #13 |
Rep 4,109
Have you told it what tires you're running--there's a setting in the same screen you view the tire temp/pressure.
05-02-2019, 07:23 PM | #14 | |
Rep 217
05-02-2019, 07:32 PM | #15 |
Rep 4,109
Here's what mine is set to actually running different tires than what I've selected (I have MPSS 295R and 285F) but this was the closest.
PS: I love that your car is a typo. Hahahaha. |
05-03-2019, 10:12 AM | #17 |
Rep 427
Drives: 2019 M5 Competition
Is anyone running the 100+ MPH pressures (44/46? or whatever)? How's the ride? My F13 M6 had higher pressures for 100+ but if I remember right the jump wasn't as big. While I"m not going 100+ all the time, I've been known to venture up there on occasion and I'm thinking it might be nice to have the added safety of the recommended higher pressures. Does it make normal DD driving overly firm as far as bump transmission?
05-03-2019, 12:02 PM | #18 | |
Rep 4,109
//EDIT: actually, I didn't post a pic of the recommendations. It starts at 37psi I believe in 50F ambient. |
