04-16-2019, 03:22 AM | #1 |
Re-Builder
17
Rep 43
E-SYS - "Missing SWEs in PSdZData Directory. [C201]
I'm looking to code a 6WA to my 2014 F30 by following this guide
https://f20.1addicts.com/forums/atta...8&d=1465929213 The 6WA has been virginalised, connected to the car and when on the very last step when I select "Select Software Availability" in E-SYS i recieve the error Code:
Missing SWEs in PSdZData Directory. [C201] I've tried moving the contents of Code:
C:\Data\psdzdata\swe Code:
C:\Data\SWE Any ideas why this is happening? Thanks. |
04-16-2019, 03:31 AM | #2 |
Rep 2,302
SWE for flashing are only available in Full psdzdata.
Here the Full psdzdata https://mega.nz/#F!4lxj2aDQ!MEfV6e0KcYlBu6VAmmJniw |
04-18-2019, 12:24 AM | #3 |
Re-Builder
17
Rep 43
Thanks for the line, took a while to download and extract but got there in the end.
I'm still missing a few files for the flash. Code:
Missing SWEs in the PSdZData directory. [C201] BKOMBI_0x60 btld_00000e4e-007_051_002 swfl_00000e4f-007_055_100 swfl_00000e50-007_055_008 swfl_00000e51-007_055_007 swfl_00000e52-007_055_002 Thanks. |
04-18-2019, 02:55 AM | #4 | |
Rep 2,302
I think you're doing something wrong. |
04-18-2019, 03:18 AM | #6 |
Rep 2,302
04-19-2019, 09:32 AM | #7 |
Re-Builder
17
Rep 43
Hummmm I can't seem to get this to work, I'm hitting the below errors.
If anyone out there would like to offer your expertise and connect via teamviewer I'll more then happily buy you a beer. Code:
TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] Fatal error while executing tal! [] - [Exception - UNKNOWN] FA must not be null when trying to execute a TAL containing coding transactions Asynchrone programming failed! [C049] FA must not be null when trying to execute a TAL containing coding transactions [1358] TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] [] - [Exception - BKOMBI - 60] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_FTP has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: BKOMBI_60_ETHERNET severity: ERROR ExecutionID=2019/04/19-07:12:41.662 [BKOMBI - 60] - [Exception - BKOMBI - 60] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_SVK has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: BKOMBI_60_ETHERNET severity: ERROR TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "1min 33s". [C206] TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] Fatal error while executing tal! Asynchrone programming failed! [C049] FA must not be null when trying to execute a TAL containing coding transactions [1358] [] - [Exception - UNKNOWN] FA must not be null when trying to execute a TAL containing coding transactions |
04-19-2019, 09:40 AM | #8 |
Rep 2,302
I'm no expert for flashing ecus, but the error message is " FA must not be null...".
Is there something wrong with the FA (VO)? Is the 6WA included in the FA? Was the FA otherwise edited? And also you can try to reactivate the VCM-Update in the settings. This sometimes helped for me. |
04-19-2019, 10:52 AM | #12 |
Re-Builder
17
Rep 43
OK I'm getting somewhere, I've written the FA to the car with the addition of 6WA.
The Kombi 60 has appeared in the ECU's to be flashed, I'm only selecting "blFlash" / "swDeploy" / "cdDeploy" in KOMBI 60 and I'm not flashing any other CPUs. When I hit start I can hear all sorts happening in the car and the NBT screen goes blue, promising signs. after about 3 minutes i hit this error in the log Code:
[KOMBI - 60] - [Exception - KOMBI - 60] SVK-Ist does not match expected SGBMIDs for ecu ECUId:KOMBI_0x60. Excpected (relevant process classes only): [hwap_00000141-255_255_255, hwap_000010f9-255_255_255, hwel_000009c4-002_107_000, hwel_00000b07-001_109_000], Actual (relevant process classes only): [hwel_000009c4-002_091_049, hwel_00000b07-001_091_012, hwap_000010f9-255_255_255, hwap_00000141-255_255_255], Missing SGBMID(s): [hwel_000009c4-002_107_000, hwel_00000b07-001_109_000], Surplus SGBMID(s): [hwel_000009c4-002_091_049, hwel_00000b07-001_091_012] TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "3min 11s". [C206] |
04-19-2019, 11:02 AM | #13 |
Rep 2,302
01-23-2023, 03:06 PM | #14 | |
Rep 3
04-13-2024, 03:04 PM | #22 |
Rep 8
