M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Personal Maintenance Plan - CPO Vehicle (Fluids, Oil, etc)
      04-15-2019, 10:38 PM   #1
ForceXXV
Drives: 2018 BMW M2
Hi all!
I recently purchased a 2018 M2 that was CPO. The dealer did the break in service prior to my purchase of the car and now I have about 4k miles on it. I wanted to check here what fluids I should be filling/checking and what other preventative maintenance I can do on my own without going to a dealer.
I believe under CPO I do not have the same privileges as the standard warranty so I'd like to do as much as I can myself.
I know that for oil I should change at 10k/1yr (and I've changed oil myself on older BMWs so that's ok).
With that said, since I have CPO, how much does an annual car check-up cost and what do they do there? Do I need it or can I go about trying to do most of the common things myself?
I wanted to check here what else I should be looking for/can do myself as I start to put more miles on the car. Thank you in advance, I'm new to the forum so any help would be appreciated. Thanks all!
      05-10-2019, 11:11 PM   #2
Jmm_22
Drives: M2
Originally Posted by ForceXXV View Post
Hi all!
if you're in the US then you can transfer the maintenance for $100. It'll transfer the remainder of the 3 year maintenance. It's cheaper than an oil change from BMW.
AndrewC198910931.00
      05-28-2019, 01:11 PM   #3
Gabhart
Gabhart's Avatar
32
Drives: 2017 M2
I do not think $100 is correct. I was quoted $700 by 2 dealerships to transfer service out of the previous owners name to mine.
m2
