BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Unique to M35i parts list
      04-14-2019, 12:24 AM   #1
billnchristy
Drives: 2022 M440xi GC
I was bored tonight and did a quick scan through real oem to find the different components that the M35i has as unique (or shared with a more exotic car).
So far:
Engine cover
Intake airbox and filter
Intake cooler lines
charge air cooler
Cylinder head gasket (2 unique thickness listed)
Crankshaft
Rear bearing shell (Crank) Shared with i8 (upper only)
Piston
Con-rod
Con-rod bearing upper shared with i8
Exhaust valve shared with i8
Turbo
injectors
Transmission (hi-torque/hi efficiency aisin)
Trans oil cooler
Muffler
Engine side exhaust cat
Struts
Brakes/calipers
      07-10-2019, 10:59 AM   #2
xcelir8bmw
xcelir8bmw's Avatar
Drives: 2022 BMW M240ix
Which one? >> Transmission (hi-torque/hi efficiency aisin)
      07-10-2019, 12:24 PM   #3
billnchristy
AWF8G45
      07-12-2019, 10:21 AM   #4
xcelir8bmw
xcelir8bmw's Avatar
Torque specs?
https://www.aisin-aw.co.jp/en/produc...dex.html#sec_3
      07-12-2019, 12:55 PM   #5
billnchristy
480nm which is scary but normal x1/2 only 350
      07-13-2019, 10:06 AM   #6
Glazonyoursix
Glazonyoursix's Avatar
39
Drives: X2 M35i
Awesome thank you for this list!
      07-14-2019, 08:34 AM   #7
xcelir8bmw
xcelir8bmw's Avatar
480 Newton-Meter (N∙m)
354.02983 Foot-Pound (ft∙lb)
      07-14-2019, 08:35 AM   #8
xcelir8bmw
xcelir8bmw's Avatar
so same thing...not a lot of wiggle room...
xbimmers
