04-03-2019, 09:46 PM | #1 |
Rep 1,241
Power supply recommendation for programming
Hi folks,
Any recommendations on brand/model for a power supply to make sure my battery voltage doesn't drop when programming in ISTA? There are a lot of different ones out there and I'd like to know if there is a general consensus around here on the best (i.e. safe and reliable) one to buy for the 120V circuit in my garage. Bang for the buck is also something I'd like to consider since I don't want to spend a fortune if I don't need to. Lastly, is using a power supply bad for the battery in any way? I was under the impression that charging with a high current is bad for car batteries, so how is it that discharging the battery quickly via programming and then rapidly charging with a high Ampere power supply is okay for it? Thank you!
CP911
04-03-2019, 10:18 PM | #2 |
Rep 16,082
I don't know about ISTA, but with E-Sys it's recommended to have the engine running. I've seen some IMO pretty wacky recommendations about how large a charger is necessary to code with the engine off, though not knowing for sure how much current the iDrive consumes I can't say what you'd need with any certainty. But if it actually drew the 90 amps I've seen some say it needs the power cables to the iDrive would be as large as those to the starter motor.
04-03-2019, 10:50 PM | #3 |
Rep 1,241
Thanks for the input. I believe the 70A+ (or is it 90A+?) power supply current "requirement" for programming is when using the ICOM module and ISTA/P for programming various control units/ECU, software updates, etc. I don't believe hooking up an ENET cable (ethernet-to-OBDII) for diagnostics via ISTA/D or doing basic coding is going to use up a lot of battery power to the point where there is a need for a power supply. Someone correct me if I'm wrong here.
CP911
04-04-2019, 02:47 AM | #4 |
Rep 2,302
