03-27-2019, 09:16 PM | #1 |
Rep 28
Dropped a bolt.
Dropped the circled bolt into the hole that connects to the cavity between the kidneys ... will this bolt dislodge itself? Should I be worried about it making way to the moving parts of the engine? Fell in during reassembly after spark plug change.
03-28-2019, 10:49 AM | #4 |
Rep 10,555
I lost a 10mm socket behind the motor when changing valve cover gaskets and an air filter cover screw in front of the air box when cleaning the filter. Neither were visible and I did not take apart stuff looking. It just was not worthwhile. If I dropped a screwdriver into the accessory belt drive or an nut down an empty spark plug hole or a greasy rag onto the headers, I would definitely get it.
zic7372.50 |
03-28-2019, 11:36 AM | #5 | |
Rep 28
03-28-2019, 05:39 PM | #6 |
Rep 765
Not that you're planning to let the car sit just for a bolt but if you know where it fell there's Amazon and there's prime on this type of tool
https://www.amazon.com/TEKTON-7601-T.../dp/B000NPPC00 |
zic7372.50 |
03-28-2019, 05:43 PM | #7 |
Rep 2,747
The thing that concerns me about dropping hardware into motors is it might come out and into a tire. Yours or anyone else's. I retrieve anything that I drop..
9ers
04-23-2019, 11:27 AM | #9 |
Rep 399
I dropped a 1/4" 10 mm deep socket in the engine bay. I wasn't concerned about causing any damage, but didn't want to buy a new one. I found (and retrieved) it on top of the front suspension sub frame with this cheap borescope.
-David
