BMW X5
      03-21-2019, 12:23 PM   #1
MystroX5
MystroX5's Avatar
6290
Drives: 2020 X7 M50i/ 911
BMW Floating Center Caps..... Pics and info
The oem BMW floating center caps are a easy and effective install to give the wheels a interesting yet subtle look. They use the same technology as the Rolls-Royce center caps by keeping the logo always in the up position regardless how fast or slow your wheels are traveling. This makes sense that BMW finally came out with this for their vehicles as they own Rolls Royce. The part shown below works with all 2019 X5 M-Sport size wheels. I am sure they work with others but only confirmed the M-Sport wheels.
To install these, I recommend you take a old pocket knife and wrap the blade with blue painters tape. Use the blade to carefully pop out the oem center caps. I also recommend waxing your new center caps before install.
As you can see there are plastic clips that hold both sets of caps in place.
The finished product looks exactly like the stock caps except they spin and protrude out 2mm more. This allows the cap to spin without touching the wheel. Now while you slowdown when passing vehicles, they can see the BMW roundel in the wheel upright and not spinning with the wheel. They will wonder what kind of witchcraft BMW uses to defy physics. If your like me, you will pass them so fast they will barely be able to see your license plate so only mall cruising will this mod be noticed.. A good price from a oem BMW dealer is about $80USA for a set of 4.
salfeet84309.00
      03-30-2019, 10:17 AM   #2
X54TH
Member
X54TH's Avatar
Drives: 2019 X5 40i M Sport
Bought them today in advance of picking up the X5 in a couple of weeks. I'm a bit scared in taking a pry tool or knife to pull the Center Caps. Any other methods like a suction cup that someone has had any success?
2019 X5 Alpine White M-Sport
Software Version 11/2022.31
2023 M2 (HEA) Brooklyn Gray
2021 330i XDrive Alpine White M-Sport
bichoo280.50
      03-30-2019, 01:24 PM   #3
BMWZ4
BMWZ4's Avatar
1910
Drives: '23 X1/'23 Allroad Progressiv
Plastic pry tool will do the trick. Zero risk of damage to the rim or cap being removed
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
      03-30-2019, 03:53 PM   #4
X54TH
Member
X54TH's Avatar
I also ordered one of these but not sure if it will be strong enough. I have the plastic pry tools. I didn't think they were thin enough.
      03-30-2019, 03:56 PM   #5
BMWZ4
BMWZ4's Avatar
1910
Could work, but the pry tools don't need to be too thin. There's a set on amazon for $8 or $12...5 or 6 different sizes.
      03-30-2019, 04:39 PM   #6
X54TH
Member
X54TH's Avatar
Got them. I hope they work. Not confident enough that suction cup will pull them out. If neither works it will have to wait until next year when I go from winters to summers. I may put them on the M2's Summer setup and wait to see if I can get them off. They fit on these.
bichoo280.50
cptcolo102.00
      03-30-2019, 04:54 PM   #7
BMWZ4
BMWZ4's Avatar
1910
You'll be fine! Nice rims btw!!
X54TH899.00
      03-30-2019, 07:09 PM   #8
ZuerstBMW
¡Viva España!
ZuerstBMW's Avatar
373
Drives: 2023 230i Mineral White
Yes, the suction cup will work, Ive used for cap removal before
23 G42 230i Mineral White Cognac, Aluminum With Mesh Effect Interior Trim MODS Clear Guard, 15% Ceramic Tint, Floating Caps
X54TH899.00
      04-02-2019, 06:22 PM   #9
X54TH
Member
X54TH's Avatar
This doesn't work as the surface needs to be "perfectly" flat. The ridges on the cap prevents an even surface. I tried the plastic pry tool and that was just too flimsy. So I took a tiny flat head screw drive and popped one off. I tried this on my son's M2 OEM wheels. If only he knew LOL.
      04-12-2019, 02:10 PM   #10
Ferg
Master of my own domain!!
Ferg's Avatar
153
Drives: F82 M4/F15 X5
Um, remove wheel and pop out form the back side?
Wild Blue3683.50
      04-12-2019, 02:54 PM   #11
X54TH
Member
X54TH's Avatar
Yes, absolutely that would be the best way but I have no desire to jack up the car to do that. The other option is to wait until the winter and do that during the change over but I guess that would be the Spring as I wouldn't bother to use them on the winter setup.
      04-12-2019, 03:14 PM   #12
MystroX5
MystroX5's Avatar
6290
They are extremely easy to pop off from the front. Skill level of about 1 out of 5. Once you pry out one edge, use your finger nails to work around and pull out.
      04-12-2019, 06:39 PM   #13
ZuerstBMW
¡Viva España!
ZuerstBMW's Avatar
373
Make sure the tool is open(the one side needs to be pushed down, then attach to cap, then close the suction cup handles and it will grasp the cap and pull it free) and is slight damp then close it and it will pop right out. I just did mine the other day, took 2 seconds.
      04-12-2019, 06:48 PM   #14
ZuerstBMW
¡Viva España!
ZuerstBMW's Avatar
373
I just made sure the suction part was damp so the suction grabbed it easier.
X54TH899.00
      04-12-2019, 09:11 PM   #15
X54TH
Member
X54TH's Avatar
Ok. I'll give it ago on Thursday when I finally get the X5. Appreciate the tip.
      04-20-2019, 01:24 PM   #16
bizfiend
bizfiend's Avatar
Drives: Renting Corolla lol
I got this sick little gimmick too. I put them on when changing wheels.
      04-20-2019, 01:28 PM   #17
X54TH
Member
X54TH's Avatar
My dealership put them on for me at the time of delivery. I lucked out.
      04-21-2019, 04:58 AM   #18
bizfiend
bizfiend's Avatar
I just hope they don't get stolen
      04-21-2019, 11:50 AM   #19
X54TH
Member
X54TH's Avatar
If they do they'll get a bonus with the M Valve caps. If they wait long enough they'll get the black badging with some dental floss.
      04-21-2019, 12:44 PM   #20
bizfiend
bizfiend's Avatar
If they do they'll get a bonus with the M Valve caps. If they what long enough they'll get the black badging with some dental floss.
Next they'll tow the whole car away.
      04-21-2019, 01:52 PM   #21
X54TH
Member
X54TH's Avatar
If they knock on the door, I'll give them the keys. If you don't tow them right they screw up the suspension.
bichoo280.50
      04-28-2019, 10:45 PM   #22
bizfiend
bizfiend's Avatar
The fitting is actually different and a lot tighter than the stock caps. It's actually pretty high quality, the clips are a lot larger and stronger. They would need to be pushed out from the inside to get them out. It would be pretty difficult to steal them.
xbimmers
