03-17-2019, 08:07 AM | #1 |
Rep 7,484
435d Walnut Blasting. Experiences?
The 435d is at 75k.
Some mornings the idle is a bit high and lumpy. Feels a bit down on power on lower RPM but absolutely fine after. Had EGR recall. Not replaced but cleaned and reassembled. Don't think it's the EGR. Thinking about having it walnut blasted. Place in Camberley called TVG Automotive. Thanks |
03-17-2019, 08:13 AM | #2 | |
Rep 3,967
03-17-2019, 08:30 AM | #3 |
Rep 7,484
Other than the odd hard start in winter the car always starts. The pre-warming took 30 seconds some days. No white smoke on start up. There are days when there is no lumpy idle. No fault codes. Will connect up to it and try check parameters if there any for the glow plugs.
03-17-2019, 09:23 AM | #4 |
Rep 4,653
Have you tried any DPF cleaner/catcleaner etc ?
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
03-17-2019, 09:32 AM | #5 |
Rep 7,484
03-17-2019, 10:20 AM | #7 |
Rep 7,032
Drives: 335xd Msport +
You running supermaket fuel?
My 335xd sounds and feels like a bag of rusty nails on Sainsbury stuff
03-17-2019, 11:03 AM | #8 |
Rep 7,484
03-17-2019, 11:15 AM | #9 |
Rep 8,501
Someone did a write-up on the Forum about TWG and he was happy with their service.
I had my 30D walnut blasted at Autowerx in Milton Keynes and they did a good job. Can't say I noticed a night and day difference, but it TRVs more sweetly to the top end. The inlet manifold and ports were getting quite heavily fouled and it's good to have them thoroughly cleaned.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
Soul_Glo13352.00 |
03-17-2019, 12:01 PM | #10 |
Rep 364
Had my 520d walnut blasted by PMP cars in Nuneaton, definitely noticed a difference. It was done just shy of 100k miles and I got to see the inlet manifold and intake ports before they were cleaned and I was quite shocked how much crap had accumulated!
It felt like it just 'pulled' a lot stronger |
Soul_Glo13352.00 |
03-17-2019, 01:05 PM | #11 | |
Rep 7,484
Price updated. They quoted the wrong amount. |
03-17-2019, 01:07 PM | #12 | |
Rep 7,484
03-17-2019, 01:57 PM | #15 | |
Rep 8,501
The whole process took around 5 hours.
03-17-2019, 02:07 PM | #16 |
Rep 8,501
I have found that the engine is running a lot smoother now, but it seems to be a combination of factors : clean IM and ports; Archoil AR6400-D Max engine / fuel system / DFP cleaner; and having the EGR coded closed (to all - spare me the lecture; I am not convinced that the theoretical benefits of EGR for NOX reduction outweigh the additional maintenance costs and fuel consumption).
Coding the EGR closed has made the biggest positive difference to engine smooth running. The annoying diesel tapping on light throttle between 1500-2000rpm has now all but gone, which supports my suspicion that this was related to poor combustion when the EGR was open. Last week I did an intermediate oil change. Used LiquiMoly engine flush to (if you believe the bumf) clean all the internals, oil pathways, piston rings, etc. Yes, modern oils should have sufficient detergents to do this, but there's no harm in using a dedicated flush. Castrol GTX 5/30 LL04 and an OEM oil filter. It's running better now (83,000 miles) than it ever has : smooth, pulls well, less harsh above 4,000rpm, and the lack of diesel tapping (probably 90% gone) has been long awaited.
Soul_Glo13352.00 |
03-17-2019, 02:21 PM | #17 |
Rep 1,993
Drives: F30 335d
Who did you get to code out the egr? What was the cost?
03-17-2019, 04:22 PM | #18 |
Rep 8,501
It was done as part of the remap. Not sure they'd want me broadcasting it, but several tuning companies offer it.
03-18-2019, 12:21 AM | #20 |
Rep 7,484
https://www.e90post.com/forums/showthread.php?t=1401027
Did this yesterday. Used wife's old hairpin. Will test today. |
03-18-2019, 05:24 AM | #21 | |
Rep 8,501
03-18-2019, 01:35 PM | #22 |
Rep 7,484
Error codes as mentioned in the link.
Check engine light. Runs smoother though and 1-2 mpg increase. Going to get a tune to have it coded out and bypass the cooler. |
