F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Precision Raceworks Ignition Kit - DIY
Extreme Powerhouse
      03-14-2019, 04:05 PM   #1
MineralF30
Drives: 09 E92 335i
I recently purchased the igniton kit from Precision Raceworks and installed them on my car. When i was searching the web, I found a lot of DIY's for the N54 platform but none for the F series N55 platform, so i figured why not make my own and share it on this forum. This is my first time making a DIY on a forum so i apologize if i miss some things during the install. This took me about an hour to install.
Tools needed:
- 11mm Socket
- T25 Torx or 4mm allen (I think)
- Sawzall (or heavy duty knife to cut through thick plastic)
1. Start by removing your engine cover if you have it installed. Unbox the kit and lay everything out. You should have:
- 6 PR blocks
- 6 Coils
- 6 Wire Adapters
- 10 Allen Screws
- 5 brackets total, 2 of them will be used to mount the blocks on the fuel rail.
View post on imgur.com
2. Locate the screws that hold the fuel rail in place. There are (4) 11mm bolts and they sit right above the intake manifold studs. You will only be using the 2 outer bolts to mount the brackets.
3. Loosen the first fuel rail bolt closest to the front of the car. Next, take 2 of the blue blocks, 2 of the allen head screws, and one of the mounting brackets supplied in the kit and connect them together (I did not have this allen head size so I used a T25 Torx bit). It should look like this when you're done:
**NOTE: I had the bracket flipped the wrong way when i took this picture, the tab should be facing downwards**
After those two are connected, insert the bracket behind the fuel rail bolt and re-tighten it. If you have trouble, loosen the bolt some more or take it completely out and align the bracket that way, just be careful and don't drop the bolt.
4. Next, you're going to need to remove this piece that sits on the manifold. I used a sawzall with a metal blade to cut mine.
https://imgur.com/a/ic7VgSp Be careful not to cut too deep or damage anything while doing this!! The result should look similar to thi">https://imgur.com/a/ic7VgSp Be careful not to cut too deep or damage anything while doing this!! The result should look similar to thi">View post on imgur.com
5. Use the other (3) flat brackets supplied in the kit to connect the rest of the blue blocks until you get to block #5. Once you reach the 5th block, you will repeat the same process you did for the 1st and 2nd blocks. After they are all connected and mounted, they should sit like this:
6. Remove your old coil packs from the engine and grab the harness supplied in the kit.
Take the blue end of the harness and connect it to the 1st coil pack connector, then connect the green end to the 1st PR block you just installed. Repeat this until you have all 6 installed and it will look like this:
7. Next, install the coil into the 1st cylinder and push down until you feel it click in place. Take the coil connector and install it in the 1st block.
Repeat this for all 6 cylinders.
After you finish this install, you can go into MHD and check off "Precision Raceworks ignition kit", and re-flash your map.
alexng72147.00
      03-22-2019, 08:57 PM   #2
insane11
Drives: 435i GC
Why do you need to flash? Is there a voltage difference
      03-23-2019, 07:38 AM   #3
MineralF30
Drives: 09 E92 335i
I don't think it is required to flash, but if you have MHD it will help out with power if you check the box.
      03-23-2019, 08:08 AM   #4
insane11
Drives: 435i GC
http://www.precisionraceworks.com/in...&product_id=89
Is this the one you got.. It look different from the pic so I'm just making sure
      03-23-2019, 09:27 AM   #5
MineralF30
Drives: 09 E92 335i
http://www.precisionraceworks.com/in...;product_id=89
Yes, that's the same kit. It works for E and F series N55.
      03-24-2019, 07:24 PM   #6
IK6SPEED
Drives: BMW M3 / AH3
      03-25-2019, 12:26 PM   #7
alexng72
Drives: 2015 F32 435i Black Msport
Tools needed:
- 11mm Socket
- 6 PR blocks
- 6 Coils
- 6 Wire Adapters
- 10 Allen Screws
3. Loosen the first fuel rail bolt closest to the front of the car. Next, take 2 of the blue blocks, 2 of the allen head screws, and one of the mounting brackets supplied in the kit and connect them together (I did not have this allen head size so I used a T25 Torx bit). It should look like this when you're done: https://imgur.com/JAonOOk
4. Next, you're going to need to remove this piece that sits on the manifold. I used a sawzall with a metal blade to cut mine. https://imgur.com/a/ic7VgSp Be careful not to cut too deep or damage anything while doing this!! The result should look similar to this. https://imgur.com/a/ELd5i1y
Nice post bro. Thank you for doing this!
      06-18-2019, 07:07 PM   #8
zookerjr5
Drives: 2012 335i
2012 BMW 335I  [0.00]
After you install I am guessing you are unable to use engine cover anymore correct?
      06-25-2019, 06:29 PM   #9
MineralF30
Drives: 09 E92 335i
I don't know, I never tried. I usually leave mine off to allow heat to escape easier.
      06-27-2019, 09:37 AM   #10
428iSoCal
428iSoCal's Avatar
Drives: 2014 428i F32
2014 BMW 428i  [0.00]
If you go to the website for the coil kit it shows the cover reinstalled. I would guess that the loss of one cover connector you can still use it.
      07-11-2019, 05:27 PM   #11
pongkin
Drives: f30
you won't be able to mount the engine cover with the pr coils
i hack the engine cover to fit it
https://ibb.co/N7jC623
      09-03-2019, 06:42 PM   #12
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Can this not be installed without trimming that engine cover piece?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      09-03-2019, 08:10 PM   #13
MineralF30
Drives: 09 E92 335i
I don't think so. You can either put them on and leave the cover off or you'll have to trim it. I usually just leave my cover off, keeps the temps down a bit.
963mw331.00
      09-15-2019, 10:37 PM   #14
Onizukachan
Great Teacher
Onizukachan's Avatar
1086
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
why not just mount your gm coils on the fender instead of having to lose the engine covers?
      09-17-2019, 01:02 PM   #15
ComputersAre8ad
Drives: F30 335i EB
Genuine question but is there a need for the engine cover aside from aesthetics?
      10-16-2019, 02:04 PM   #16
bsebou21
Drives: 2014 435i xDrive
PR Coil pack
how do you like this setup with a stock turbo? Also, if you have to replace one of the coils, how would you do so?
      10-16-2019, 03:21 PM   #17
MineralF30
Drives: 09 E92 335i
I have an upgraded turbo now. Honestly, this isn't a mod that you'll necessarily notice power wise, I did it mostly for peace of mind so I wouldn't have to change my coils so much.
If a coil does break though I think you just email the company and they'll send you a new one.
      10-17-2019, 10:00 AM   #18
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
I totally agree with that - I'm running Stg2 turbo and everything is fine using the stock OEM coils - I did go with colder plugs, but see no reason to go with the coils if OEM performs fine...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      10-17-2019, 10:03 AM   #19
MineralF30
Drives: 09 E92 335i
Yeah, I did it mostly for looks and for the future when I was going to upgrade. I'm running a 6159 spooly boi now so I think it helps with timing etc
      04-06-2021, 11:11 PM   #20
enlimalima
Drives: 335i F30 PWG
kewl,,,finally a PR coil install on an F chassis...
335i F30 PWG, PS2, XDI-35, ER DP, CSF FMIC, MST AI, BM3, Snow Perf WMI
f30post
