03-14-2019, 12:57 PM | #1 |
Rep 18
Drives: 2013 BMW 320xi
Bimmercode Expert Mode vs. Cable Computer Method (E-Sys)
Is there a difference in coding opportunities between the two? There is a lot of threads showing different features to code. But can I do the same procedure in the Expert Mode in Bimmercode. Thinking of getting Bimmercode since I didn't have that opportunity with iCarly.
Apologies in advance if this is a duplicate question already asked. |
03-14-2019, 01:08 PM | #2 | |
Rep 332
I have found that using E-Sys to browse through the settings, and also examining CAFD files with TokenMaster's free NcdCafdTool gives a greater understanding of what's going on, and reduces the chance of making silly changes. Even if you just use them to identify the items to be modified, using Bimmercode/Expert is then much easier and safer. If you don't want to get into the messy business of keeping the Launcher program working, you can still use E-Sys to download CAFD data and then browse it with NcdCafdTool. |
03-15-2019, 08:22 AM | #3 |
Rep 5,457
Drives: F30
Would changing from Steptronic transmission to Sports Auto Transmission (option code 2TB) be considered a VO coding change?
03-15-2019, 08:42 AM | #4 |
Rep 332
Someone here will give you a fully qualified answer. My (guess) is that this can only be achieved by changing a VO entry and not by FDL coding. If so, you need E-Sys.
03-15-2019, 11:15 AM | #6 |
Rep 332
I would think that finding out all the FDL changes (for Bimmercode) required in implementing 2TB would be a lot harder than just VO coding it with E-Sys.
03-15-2019, 09:47 PM | #7 |
Rep 5,457
Drives: F30
I have not found a single "reasonable" instance where BimmerCode / BimmerLink has fallen short.
03-15-2019, 09:48 PM | #8 | |
Rep 5,457
Drives: F30
Took me about 6 minutes total. |
03-16-2019, 04:52 PM | #10 |
Rep 332
So what is your point? You asked if SAT is considered VO coding; yes it is if you want to explicitly add 2TB to the FA. If you just want to FDL code all the implied changes, assuming you know what they are, then you don't need to VO code, as you have proved.
03-16-2019, 06:03 PM | #11 | |
Rep 5,457
Drives: F30
You implied that it was challenging or difficult for the non-coder or first timer. |
03-16-2019, 06:04 PM | #12 |
Rep 5,457
Drives: F30
03-16-2019, 06:41 PM | #13 |
Not stock
474
Rep 614
you will need to code it when you upgrade to sport brakes... fdl is fine for little stuff but somethings, like performance brakes, need VO coding
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
